I’m not sure what you mean by device type, but the chip under the label says:
Quectel EG95-NA.
It is a USB based LTE modem. I can see it with lsusb but I cannot see it using mmcli.
We have temporarily used a different modem that works, but I would like to hear if you end up supporting this modem.
Is there a specific single board computer running balenaOS where the EG95 modem is being connected? For example Raspberry Pi 3 model B+ or Raspberry Pi Zero W?
The device is 64-bit x86. The specific model in this case is Advantech UNO-137 which has an Intel Atom E3940 processor. The modem could be used on other x86 devices though.
