Hello together,
I would like to ask you whats the best version to mount a external USB-Drive for my nextcloud docker image (Docker) for my raspi3/raspi4.
There are many posts about the usage of a base image of balena… but I have to use the nextcloud image… So I would like to ask you about the best to do in 2023.
- Use a multistage build and use for example nextcloud as base image (layer 1)?
=> so I have to manually copy all nessessary files inclusive entrypoint.sh from nextcloud image to the
balena image in a higher layer… - manually build some udev rules in my custom nextcloud image?
- get fstab working in my nextcloud image and use the build in nextcloud entrypoint.sh files…
=> I tried this already but have problems with permissions… entrypoint of nextcloud procedere is not
able to run as root
I think I need some input if one of this points is the right way, or if there is a other way available…
Thank you!
Alex
