Hoping to get some clarification on working with external drives. I know I am likely missing a key concept somewhere with regards to what the correct way is to do this and some of the documentation seems to contradict itself but in any case, I have a cluster of 3 RPI4s and a RPI3 on the balenaOS 2.44.0+rev3 OS. Right now I am trying to spin up a NextCloud Container and followed the guide here and added the fstab edits to my dockerfile:
FROM lsiobase/nginx:3.10
# set version label
ARG BUILD_DATE
ARG VERSION
ARG NEXTCLOUD_RELEASE
LABEL build_version="Linuxserver.io version:- ${VERSION} Build-date:- ${BUILD_DATE}"
LABEL maintainer="sparklyballs"
# environment settings
ENV NEXTCLOUD_PATH="/config/www/nextcloud"
ENV UDEV=1
RUN echo "LABEL=storage1 /data/storage1 ext4 rw,relatime,discard,data=ordered 0 2" >> /etc/fstab && \
echo "LABEL=storage2 /data/storage2 ext4 rw,relatime,discard,data=ordered 0 2" >> /etc/fstab
RUN rc-service localmount start
RUN \
echo "**** install build packages ****" && \
apk add --no-cache --virtual=build-dependencies --upgrade \
autoconf \
automake \
file \
g++ \
gcc \
make \
php7-dev \
re2c \
samba-dev \
zlib-dev && \
echo "**** install runtime packages ****" && \
apk add --no-cache --upgrade \
curl \
ffmpeg \
imagemagick \
libxml2 \
php7-apcu \
php7-bz2 \
php7-ctype \
php7-curl \
php7-dom \
php7-exif \
php7-ftp \
php7-gd \
php7-gmp \
php7-iconv \
php7-imagick \
php7-imap \
php7-intl \
php7-ldap \
php7-mcrypt \
php7-memcached \
php7-opcache \
php7-pcntl \
php7-pdo_mysql \
php7-pdo_pgsql \
php7-pdo_sqlite \
php7-pgsql \
php7-phar \
php7-posix \
php7-redis \
php7-sodium \
php7-sqlite3 \
php7-xmlreader \
php7-zip \
samba-client \
sudo \
tar \
unzip && \
echo "**** compile smbclient ****" && \
git clone git://github.com/eduardok/libsmbclient-php.git /tmp/smbclient && \
cd /tmp/smbclient && \
phpize7 && \
./configure \
--with-php-config=/usr/bin/php-config7 && \
make && \
make install && \
echo "**** configure php and nginx for nextcloud ****" && \
echo "extension="smbclient.so"" > /etc/php7/conf.d/00_smbclient.ini && \
echo 'apc.enable_cli=1' >> /etc/php7/conf.d/apcu.ini && \
sed -i \
-e 's/;opcache.enable.*=.*/opcache.enable=1/g' \
-e 's/;opcache.interned_strings_buffer.*=.*/opcache.interned_strings_buffer=8/g' \
-e 's/;opcache.max_accelerated_files.*=.*/opcache.max_accelerated_files=10000/g' \
-e 's/;opcache.memory_consumption.*=.*/opcache.memory_consumption=128/g' \
-e 's/;opcache.save_comments.*=.*/opcache.save_comments=1/g' \
-e 's/;opcache.revalidate_freq.*=.*/opcache.revalidate_freq=1/g' \
-e 's/;always_populate_raw_post_data.*=.*/always_populate_raw_post_data=-1/g' \
-e 's/memory_limit.*=.*128M/memory_limit=512M/g' \
/etc/php7/php.ini && \
sed -i \
'/opcache.enable=1/a opcache.enable_cli=1' \
echo "env[PATH] = /usr/local/bin:/usr/bin:/bin" >> /etc/php7/php-fpm.conf && \
echo "**** set version tag ****" && \
if [ -z ${NEXTCLOUD_RELEASE+x} ]; then \
NEXTCLOUD_RELEASE=$(curl -s https://raw.githubusercontent.com/nextcloud/nextcloud.com/master/strings.php \
| awk -F\' '/VERSIONS_SERVER_FULL_STABLE/ {print $2;exit}'); \
fi && \
echo "**** download nextcloud ****" && \
curl -o /app/nextcloud.tar.bz2 -L \
https://download.nextcloud.com/server/releases/nextcloud-${NEXTCLOUD_RELEASE}.tar.bz2 && \
echo "**** cleanup ****" && \
apk del --purge \
build-dependencies && \
rm -rf \
/tmp/*
# copy local files
COPY root/ /
# ports and volumes
EXPOSE 443
VOLUME /config /data
and gave access in my docker-compose:
version: '2'
volumes:
resin-data:
services:
nc:
build: ./docker-nextcloud-master
privileged: true
network_mode: host
devices:
- '/dev:/dev'
ports:
- "443:443"
volumes:
- "resin-data:/data"
- "resin-data:/config"
NextCloud boots up just fine but I am not able to see the folders where I mounted my drives at. I also enabled external storage and tried to add them via the extension I mounted them to and still a no-go. Any ideas?
