We have an array of different Balena OS devices that are collecting data for us while being connected to cellular using a USB Modem. They are having issues that cause them to not connect to the internet.
I am running balenaOS 2.45.1+rev1 with the gsm connection config files:
[connection]
id=cellular
type=gsm
autoconnect=true
autoconnect-priority=2
autoconnect-retries=0
[gsm]
apn=hologram
[serial]
baud=115200
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
AND
[connection]
id=cellular
type=gsm
autoconnect=true
autoconnect-priority=3
[gsm]
apn=vzwinternet
[serial]
baud=115200
[ipv4]
method=auto
[ipv6]
method=auto
This is for both Hologram and Verizon sim cards.
I connect to ethernet to see the status of the USB Modem and I get these results
root@90b0e9e:~# mmcli -L
/org/freedesktop/ModemManager1/Modem/0 [QUALCOMM INCORPORATED] QUECTEL Mobile Broadband Module
root@90b0e9e:~# nmcli connection show
NAME UUID TYPE DEVICE
cellular 6981df61-ffe5-3454-8e0c-81a71468c0c6 gsm cdc-wdm0
Wired connection 1 0456c7b4-6d7b-37d7-b5b8-5553bd064d8a ethernet eth0
supervisor0 4474e472-a0e2-4312-a5f7-a30e813b88f0 bridge supervisor0
cellular 19e9f6b6-8100-3f4d-8655-a5363e2c3de3 gsm –
root@90b0e9e:~# mmcli -m 0
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: 7ca836896a838d330504274e46cc7de01196199c
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EC25AFFAR07A08M4G
| carrier config: ROW_Generic_3GPP
| carrier config revision: 0501081F
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 866834040553211
System | device: /sys/devices/3530000.xhci/usb1/1-2
| drivers: qmi_wwan, option1
| plugin: Quectel
| primary port: cdc-wdm0
| ports: ttyUSB0 (qcdm), ttyUSB2 (at), ttyUSB3 (at), wwan0 (net),
| cdc-wdm0 (qmi)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-pin2 (3), sim-puk (10), sim-puk2 (10)
| state: connecting
| power state: on
| access tech: umts
| signal quality: 54% (recent)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| current: allowed: 3g, 4g; preferred: 4g
Bands | supported: utran-4, utran-5, utran-2, eutran-2, eutran-4, eutran-5,
| eutran-12, eutran-13, eutran-14, eutran-66, eutran-71
| current: utran-4, utran-5, utran-2, eutran-2, eutran-4, eutran-5,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 866834040553211
| operator id: 310260
| registration: home
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
Bearer | dbus path: /org/freedesktop/ModemManager1/Bearer/8759
Does anyone know why the modem would be stuck in this connecting state? This is with a Hologram sim card.
