Manifest for balenalib/intel-nuc-node:17.4 not found manifest unknown: manifest unknown
I’m getting the below errors when I try and build for an intel-nuc-node:17.4
The reason I’m restricting to 17.4 node version is because I need my node server to work with Raspberry Pi 4 Balena OS as well. Is there a list of the various node versions supported with the different devices for Balena OS? Any assistance is apprecaited.
Cheers,
Spen
The below image is the reason I made the choice for Node Version 17.4 as I am using Raspberry Pi 4 and Intel Nuc, and thought from the below table that 17.4 would work for both?
It seems that the nodejs LTS version is 16.14.0, which is in the balenalib docker images for both the amd64 and aarch64, I believe:
Hence I’ll change to 16.14 for the version of our nodejs from 17.4, hopefully this will solve this issue.
This has not solved the issue, I am getting the same error for the intel_nuc build.
Usually means the image isn’t available, probably because the build hasn’t been run or failed on Balena’s end where they build the images. The Balena images are a little patchy, I often come across missing images.
Are you using anything on the device that requires the Balena official images? I ended up just using the official node images, they are more predictable and versioned nicely. Also smaller.
