Is there a way to tell witch log message is from the resinOS logging and witch from the ‘main’ app service?
27.04.18 21:38:51 (+0200) Starting service 'main sha256:0c0b516ffab06e5e1b8cdb8793b388b71c9e0147ffed22665eca2ed28b1f028f'
27.04.18 21:39:03 (+0200) * service udev added to runlevel default
27.04.18 21:39:03 (+0200) OpenRC init system enabled.
27.04.18 21:39:03 (+0200) OpenRC 0.24.1.a941ee4a0b is starting up Linux 4.4.60-yocto-standard (i586) [LXC]
27.04.18 21:39:03 (+0200) * /proc is already mounted
27.04.18 21:39:03 (+0200) * Mounting /run ...
27.04.18 21:39:03 (+0200) * /run/openrc: creating directory
27.04.18 21:39:03 (+0200) * /run/lock: creating directory
27.04.18 21:39:03 (+0200) * /run/lock: correcting owner
27.04.18 21:39:03 (+0200) * Caching service dependencies ...
27.04.18 21:39:06 (+0200) Started service 'main sha256:0c0b516ffab06e5e1b8cdb8793b388b71c9e0147ffed22665eca2ed28b1f028f'
27.04.18 21:39:08 (+0200) [ ok ]
27.04.18 21:39:09 (+0200) * Starting D-BUS system messagebus ...
27.04.18 21:39:13 (+0200) [ ok ]
27.04.18 21:39:13 (+0200) * Starting Resin.io User Application ...
27.04.18 21:39:14 (+0200) [ ok ]
27.04.18 21:39:18 (+0200) This program can only be run on processors with MMX support.
This MMX warning is it issued from resinOS? Thanks, Bas
