Apologies if this should be in a different category.
I’m am using livepush to update a container on my device, but it is missing a required step to fully apply the changes. Here is the Dockerfile:
FROM balenalib/raspberrypi3-node:8-build AS ui-build
WORKDIR /src
RUN npm config set registry https://registry.npmjs.org/ \
&& npm install -g -s --no-progress yarn
COPY ./ui/package.json ./
RUN yarn
COPY ./ui ./
RUN yarn run build \
&& yarn cache clean
FROM balenalib/raspberrypi3-python:3.6
ENV DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
dnsmasq \
libdbus-glib-1-dev \
dbus \
make \
pkg-config \
wireless-tools \
gcc \
libgirepository1.0-dev \
libcairo2-dev \
python3-dev \
gir1.2-gtk-3.0 \
WORKDIR /src
COPY ./requirements.txt /src/requirements.txt
RUN pip3 install -r /src/requirements.txt
COPY --from=ui-build ./src/dist ./server/dist
COPY . /src/
RUN rm -rf /src/ui
CMD ["python", "app.py"]
This container uses Vue.js as the frontend and Flask as the backend. When I alter code contained in the frontend (inside of the directory ui), the only steps executed by livepush are:
COPY ./ui ./
RUN yarn ...
RUN rm -rf /src/ui
The missing step that is needed to bring the newly built code into the container is:
- COPY --from=ui-build ./src/dist ./server/dist
Is there something I can change about our Dockerfile so that livepush understands to copy the resulting build from the first stage?
Hey @ejohnso49 thanks for the report, let’s get to the bottom of this.
I ran your dockerfile through the parsing routines of livepush, and it correctly detected the stage dependency, so I’m not entirely sure where the process is failing.
Could you paste the output of a running livepush please?
Also if it’s possible for you to share your entire code with me, that would be amazing.
Hi Cameron,
Sorry for the delay getting back to you. I did a few experiments today with livepush and I logged the output from this. I made a change to my code and ran balena push, this change was reflected correctly when I ran my test. Then I made another change while the livepush was still running but in this case I did not see that reflected in my test. I will send you the output from this. Thank you for the help
Thanks for sending that over @ejohnso49
What’s interesting is that the commands from the second stage definitely get executed, so it will have at least attempted to perform the copy too.
Can you take a look at the source tree of the container, and see if it’s been added to a slightly wrong location please? For example ./sever/dist/dist or some other weirdness - I saw a lot of this kind of stuff when initially developing livepush so perhaps there’s an edge case that wasn’t caught.
I’m not entirely sure the source of my problems before with this container, but recently updated the supervisor to v2.43.0 and updated the CLI to 11.17.4 and it seems like this issue was fixed since then. Also trying to move us away from the original design of that service so that could have eliminated a typo/error in the recipe to begin with.
Thanks for the update, do you remember what version of the CLI you were using when you saw the bug you reported?
I think it was around v11.0.7 because around that time I remember trying to update the CLI to see if that fixed the issue.
