Hello community,
I’m trying to effectively limit each of my containers CPU usage in a multi-container environment.
The resin documentation lists a subset of docker compose version 2.1, but also lists “cpus” as a possible value, while the docker documentation lists this attribute as introduced in compose version 2.2
It’s all fine, “cpus” results in:
[Error] Could not parse compose file
[Error] data/services/$name should NOT have additional properties
So I guess it’s just a documentation error, however I’m trying to use cpu_quota and cpu_period now, since they should be available in 2.1 cpu_period is neither mentioned in the supported nor in the unsupported section of the resin documentation though. But I tried and it is not available currently.
This again is fine in my case, but I need the value of cpu_period to find out which cpu_quota I have to supply the containers with. I couldn’t find anything on a default value in resin, but I know the default docker value should be 100000 (microsecond units I believe, even though the docker documentation lists the default at 100 microseconds - again a documentation error, as I came to believe after googling about it).
My question is whether this value is maintained in resin? So that I can safely assume, that I will use max 1 CPU if I supply my container with a quota of 100000.
The documentation articles I am referring to are:
Thanks in advance,
Tarek
