I am currently running 3 different containers in the same RPI, things working fine. I am now looking at the docker documentation to fine tune the containers by setting parameters such as CPU affinity, memory swappiness and more. In particular, I would like to reserve one CPU core to a process, and let the other processes run on any of the remaining three (running on RPI 3). I am wondering how the balena supervisor, which is itself a container, stands in this scenario. Is it possible to set its CPU affinity? Otherwise, how is it possible to ensure it does not interfere with the rest of the setup?
Thank you.
