Im trying to build libreNMS, but compose file seems not compatible.
It seems has issues with the name data/name should be object and the services data/services should NOT have additional properties attributes.
Maybe someone could help? Is there already any existing libreNMS Project/App?
Thx a lot,
Meg
Hey @Megachip , just to confirm you are attempting to push that compose file to a balena fleet?
At a high level here are the compose properties we try to support:
So I do see some incompatibilities in your compose file.
- balena only supports named volumes, not bind volumes (docs)
- balena does not support the env_file instruction (docs)
- balena does not support the container_name instruction (docs)
The other fields should be fine, but note that the long form of ports may not be supported by all versions of the supervisor, so I suggest the short syntax where possible.
ports:
- 8000:8000/tcp
I hope this helps!
