Compose file docker-compose.yml seems not correct
Hi there I try to setup Balena App with TTN and Raspberry Pi to collect and store data.
I have everything setup using this link:
Now the step to push the yml file to the App / or in the PI fails…
Who could let me know wha tis wrong with the file?
I attached the yml file (as a TXT file otherwise unable to uplaod)
docker-compose.txt (674 Bytes)
and a screenshot of the error I get.
Hello @chrisvr thanks for your message and welcome to the balena forums!
I downloaded your docker-compose but it looks like you have issues on the identiation of the services. Could you please check it’s similar than this?
version: '2.1'
volumes:
    database:
    dashboard:
services:
    connector:
        image: balenablocks/connector:raspberrypi3
        restart: always
        labels:
          io.balena.features.balena-api: '1'
        privileged: true
        environment:
          - 'ENABLE_EXTERNAL_HTTP_LISTENER=1'
        ports:
          - "8080"
    influxdb:
        image: influxdb@sha256:b4529fd53e9022bd1e83aaf04c6c6a1ebfffdfa112c31367d69da1354983a24b
        container_name: influxdb
        restart: always
        volumes:
            - 'database:/var/lib/influxdb'
    dashboard:
        image: balenablocks/dashboard:raspberrypi3
        restart: always
        ports:
            - "80"
        volumes:
            - 'dashboard:/data'
Let us know if this works!
Thanks for your quick reply.
What do you mean with ’ you have issues on the identiation of the services ’ ?
What i meant was that connector, influxdb and dashboard services should be under the services and not at the same level (as i see on the txt that you shared).
Aah I see, many thanks. It is processing now to Balena cloud. Really appreciated it. Now I have to work on ’ capturing and storing the data for visualisation
Yes! let us know if that works :slight_smile:
It works. Now following the steps at this url
I need to use HTTP integrations on TTN Gateway Application… but no option anymore for HTTP integrations - see screenshot.
An
y updated manual from you end?
Did you try to use Webhooks and then Custom webhook?
I will update the documentation!
Yes I tried but need more specific info I think form your end like:
webhook format
base url
downlink api key
and some others (see screenshot)
Hello @chrisvr my cubecell was not working! Testing now and updating the docs on our side :slight_smile:
i will keep you updated!
Allright @chrisvr finally it worked on my side!
First of all you need a decoder function that should run on your End Device section.
Then go to Integrations > WebHooks and then Custom Webhook
Check the Uplink message checkbox! and that should work!
Let me know if that worked for you!
Hello @chrisvr I’m writing to you again to see if you could configure properly your LoRa node on The Things Stack.
We also updated the blogpost here Build a solar-powered weather station with LoRa & The Things Network
