I have an IOT-gate-imx8 that was flashed and working with balenaOS 5.3.23. I then attempted to replace the OS with Compulab’s Debian image following these instructions.
Unfortunately after running cl-deploy from those instructions, I’ve somehow managed to put my device in a kernel panic and it never boots to BalenaOS (or Debian).
Here is the output from minicom -D /dev/cu.usbserial-028A400C 115200 on my Mac connected to the console port by USB.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.32-iot-gate-imx8m-3.2.2+ (oe-user@oe-host) (a2
[ 0.000000] Machine model: CompuLab SB-IOTGIMX8 board
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030880000 (options '115200')
[ 0.000000] printk: bootconsole [ec_imx6q0] enabled
[ 0.111413] No BMan portals available!
[ 0.112797] No QMan portals available!
[ 0.336835] caam_jr 30901000.jr: failed to flush job ring 0
[ 0.413223] rtc-abx80x 1-0069: Create sysfs group: 0
Starting version 250
[ 1.921603] sd 0:0:0:0: [sda] No Caching mode page found
[ 1.932533] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3.282911] Kernel panic - not syncing: Attempted to kill init! exitcode=0x07
[ 3.298221] CPU: 2 PID: 1 Comm: init Not tainted 5.15.32-iot-gate-imx8m-3.2.1
[ 3.313171] Hardware name: CompuLab SB-IOTGIMX8 board (DT)
[ 3.324124] Call trace:
[ 3.328997] dump_backtrace+0x0/0x1a0
[ 3.336313] show_stack+0x18/0x24
[ 3.342926] dump_stack_lvl+0x68/0x84
[ 3.350237] dump_stack+0x18/0x34
[ 3.356849] panic+0x160/0x358
[ 3.362942] do_exit+0x99c/0x9ec
[ 3.369385] do_group_exit+0x38/0xa0
[ 3.376518] get_signal+0x160/0x8f0
[ 3.383480] do_notify_resume+0x22c/0x1310
[ 3.391656] el0_da+0x50/0x60
[ 3.397576] el0t_64_sync_handler+0xe8/0x130
[ 3.406100] el0t_64_sync+0x1a0/0x1a4
[ 3.413411] SMP: stopping secondary CPUs
[ 3.421242] Kernel Offset: disabled
[ 3.428201] CPU features: 0x00002001,20000846
[ 3.436897] Memory Limit: none
[ 3.442991] Rebooting in 1 seconds..
Also when I run uuu -lsusb on my Mac I get 0 Connected Known USB Devices.
Any idea how I can remove BalenaOS and get the device to boot into Debian?
