Hi all,
Followed the steps here without VM on Ubuntu 18. This worked perfectly for the past month but stopped working today. Tested on 2 different devkits and two different machines. Seems like a jetson-flash issue ?
Any idea what may be causing it ?
Here’s the trace :
(base) alex@alex-XPS-15-9560:~/Vizzia/jetson-flash$ sudo ./bin/cmd.js -f /home/alex/Vizzia/jetson-flash/balena-cloud-VizziaDev2-jetson-nano-2.88.4+rev1-dev-v12.11.0.img -m jetson-nano-qspi-sd
Consistency check done for /tmp/15210/Linux_for_Tegra
| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.| Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6./ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.- Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.\ Downloading and extracting https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.1_aarch64.tbz2
internal/streams/legacy.js:61
throw er; // Unhandled stream error in pipe.
Error
at new Bzip2Error (/home/alex/Vizzia/jetson-flash/node_modules/unbzip2-stream/lib/bzip2.js:31:19)
at Object.Error (/home/alex/Vizzia/jetson-flash/node_modules/unbzip2-stream/lib/bzip2.js:36:37)
at Object.bzip2.header (/home/alex/Vizzia/jetson-flash/node_modules/unbzip2-stream/lib/bzip2.js:152:39)
at decompressBlock (/home/alex/Vizzia/jetson-flash/node_modules/unbzip2-stream/index.js:18:29)
at decompressAndQueue (/home/alex/Vizzia/jetson-flash/node_modules/unbzip2-stream/index.js:48:20)
at Stream.end (/home/alex/Vizzia/jetson-flash/node_modules/unbzip2-stream/index.js:83:17)
at _end (/home/alex/Vizzia/jetson-flash/node_modules/through/index.js:65:9)
at Stream.stream.end (/home/alex/Vizzia/jetson-flash/node_modules/through/index.js:74:5)
at Request.onend (internal/streams/legacy.js:46:10)
at Request.emit (events.js:326:22)
at IncomingMessage. (/home/alex/Vizzia/jetson-flash/node_modules/request/request.js:1076:12)
at Object.onceWrapper (events.js:420:28)
at IncomingMessage.emit (events.js:326:22)
at endReadableNT (_stream_readable.js:1241:12)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
message: ‘No magic number found’
