We’re currently having some issues with removing 1 application. When I try to delete it it just returns with the following error :
Application not found:
But I’m in that application, and the applicationid is the same as in the URL so it’s kinda strange …
Did someone also had that issue in the past ? Is there a way to fix it ?
Just as an update, I looked into this and I’ve found the specific error occuring, unfortunately I haven’t yet found the root cause for the problem. Please could you extend the support access for next week and I’ll try get to the bottom of this asap.
I believe we’ve found the issue, with it being related to a corner case of cascade deletions and dependent applications. This has been fixed and deployed to production so you should now be able to delete your application. Please do let us know if this is not the case!
Hey @russel the issue in your case seems different. You have a number collaborators added to the application, and there’s a quirk in the permission system that might block deletion in this particular case, as the devices slightly before a change that has an effect on this.
So would recommend deleting the devices (and possibly afterwards removing the collaborators from the app too), and then trying to delete the application.
I also can’t delete two balena applications: 1495589 (anysight-old-dev) and 1483886 (anysight-old-prod) with the owner of them (anysight@outlook.de). Error message: Request error: Data is referenced by delta. I deleted every related stuff I could. Can you support me on that?
