@richbayliss
Yes all our devices move forward in commits via the staged-releases scripts, as I understand it these scripts set the devices build id.
Also it deleted the volume again today. The supervisor container logs for the last 15 or so minute before the volume deletion:
[2018-07-15T04:33:14.715Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Starting delta to registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5
[2018-07-15T04:33:35.161Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Delta failed with: Error: Delta server is still processing the delta, will retry
[2018-07-15T04:33:35.173Z] Event: Image download error {"error":{"message":"Delta server is still processing the delta, will retry","stack":"Error: Delta server is still processing the delta, will retry\n at /usr/src/app/dist/app.js:618:34021\n at u (/usr/src/app/dist/app.js:9:75210)\n at A._settlePromiseFromHandler (/usr/src/app/dist/app.js:315:128550)\n at A._settlePromise (/usr/src/app/dist/app.js:315:129450)\n at A._settlePromise0 (/usr/src/app/dist/app.js:315:130149)\n at A._settlePromises (/usr/src/app/dist/app.js:315:131476)\n at A._fulfill (/usr/src/app/dist/app.js:315:130519)\n at s._resolve (/usr/src/app/dist/app.js:315:139433)\n at s._promiseFulfilled (/usr/src/app/dist/app.js:315:139774)\n at s._iterate (/usr/src/app/dist/app.js:315:139254)\n at s.t [as _init] (/usr/src/app/dist/app.js:315:138475)\n at A._settlePromise (/usr/src/app/dist/app.js:315:129488)\n at A._settlePromise0 (/usr/src/app/dist/app.js:315:130149)\n at A._settlePromises (/usr/src/app/dist/app.js:315:131476)\n at A._fulfill (/usr/src/app/dist/app.js:315:130519)\n at U._callback (/usr/src/app/dist/app.js:118:48500)"},"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:33:35.714Z] Event: Delta image download {"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:33:35.745Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Starting delta to registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5
[2018-07-15T04:33:42.196Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Delta failed with: Error: Delta server is still processing the delta, will retry
[2018-07-15T04:33:42.206Z] Event: Image download error {"error":{"message":"Delta server is still processing the delta, will retry","stack":"Error: Delta server is still processing the delta, will retry\n at /usr/src/app/dist/app.js:618:34021\n at u (/usr/src/app/dist/app.js:9:75210)\n at A._settlePromiseFromHandler (/usr/src/app/dist/app.js:315:128550)\n at A._settlePromise (/usr/src/app/dist/app.js:315:129450)\n at A._settlePromise0 (/usr/src/app/dist/app.js:315:130149)\n at A._settlePromises (/usr/src/app/dist/app.js:315:131476)\n at A._fulfill (/usr/src/app/dist/app.js:315:130519)\n at s._resolve (/usr/src/app/dist/app.js:315:139433)\n at s._promiseFulfilled (/usr/src/app/dist/app.js:315:139774)\n at s._iterate (/usr/src/app/dist/app.js:315:139254)\n at s.t [as _init] (/usr/src/app/dist/app.js:315:138475)\n at A._settlePromise (/usr/src/app/dist/app.js:315:129488)\n at A._settlePromise0 (/usr/src/app/dist/app.js:315:130149)\n at A._settlePromises (/usr/src/app/dist/app.js:315:131476)\n at A._fulfill (/usr/src/app/dist/app.js:315:130519)\n at U._callback (/usr/src/app/dist/app.js:118:48500)"},"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:33:43.125Z] Event: Delta image download {"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:33:43.155Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Starting delta to registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5
[2018-07-15T04:34:04.334Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Delta failed with: Error: Delta server is still processing the delta, will retry
[2018-07-15T04:34:04.360Z] Event: Image download error {"error":{"message":"Delta server is still processing the delta, will retry","stack":"Error: Delta server is still processing the delta, will retry\n at /usr/src/app/dist/app.js:618:34021\n at u (/usr/src/app/dist/app.js:9:75210)\n at A._settlePromiseFromHandler (/usr/src/app/dist/app.js:315:128550)\n at A._settlePromise (/usr/src/app/dist/app.js:315:129450)\n at A._settlePromise0 (/usr/src/app/dist/app.js:315:130149)\n at A._settlePromises (/usr/src/app/dist/app.js:315:131476)\n at A._fulfill (/usr/src/app/dist/app.js:315:130519)\n at s._resolve (/usr/src/app/dist/app.js:315:139433)\n at s._promiseFulfilled (/usr/src/app/dist/app.js:315:139774)\n at s._iterate (/usr/src/app/dist/app.js:315:139254)\n at s.t [as _init] (/usr/src/app/dist/app.js:315:138475)\n at A._settlePromise (/usr/src/app/dist/app.js:315:129488)\n at A._settlePromise0 (/usr/src/app/dist/app.js:315:130149)\n at A._settlePromises (/usr/src/app/dist/app.js:315:131476)\n at A._fulfill (/usr/src/app/dist/app.js:315:130519)\n at U._callback (/usr/src/app/dist/app.js:118:48500)"},"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:34:05.540Z] Event: Delta image download {"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:34:05.579Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Starting delta to registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5
[2018-07-15T04:34:08.023Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Applying rsync delta...
[2018-07-15T04:34:09.972Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Extracted image config
[2018-07-15T04:34:10.911Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Created empty image 17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689
[2018-07-15T04:34:28.192Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Hard-linked files from '/var/lib/docker/overlay2/tmp-cbc8e04a04861454c8bfa4578d1bfaf85b2b081282115ce06f41db4c37ba8a2a-2adJhbhW/' to '/var/lib/docker/overlay2/ea0154acccd27884cca88bf634f2716d1ae824c740c9167c63db97236d87caf3/diff/'
[2018-07-15T04:34:28.193Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Spawning rsync with arguments --archive --delete --read-batch - /var/lib/docker/overlay2/ea0154acccd27884cca88bf634f2716d1ae824c740c9167c63db97236d87caf3/diff/
[2018-07-15T04:35:08.715Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Batch input stream ended; waiting for rsync...
[2018-07-15T04:35:08.730Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): rsync exited cleanly
[2018-07-15T04:35:08.732Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): rsync exited successfully
[2018-07-15T04:35:08.733Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): fsync'ing...
[2018-07-15T04:35:09.045Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): All done. Image ID: 17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689
[2018-07-15T04:35:09.146Z] delta(registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824): Delta applied successfully
[2018-07-15T04:35:09.270Z] Event: Image downloaded {"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0,"dockerImageId":null}}
[2018-07-15T04:35:09.637Z] Event: Service kill {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":536884,"image":"sha256:cbc8e04a04861454c8bfa4578d1bfaf85b2b081282115ce06f41db4c37ba8a2a","labels":{"io.resin.app-id":"738415","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.service-id":"2092","io.resin.service-name":"main","io.resin.supervised":"true"}}}
[2018-07-15T04:35:13.668Z] Event: Service exit {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":536884,"image":"sha256:cbc8e04a04861454c8bfa4578d1bfaf85b2b081282115ce06f41db4c37ba8a2a","labels":{"io.resin.app-id":"738415","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.service-id":"2092","io.resin.service-name":"main","io.resin.supervised":"true"}}}
[2018-07-15T04:35:13.787Z] Event: Service stop {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":536884,"image":"sha256:cbc8e04a04861454c8bfa4578d1bfaf85b2b081282115ce06f41db4c37ba8a2a","labels":{"io.resin.app-id":"738415","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.service-id":"2092","io.resin.service-name":"main","io.resin.supervised":"true"}}}
[2018-07-15T04:35:14.944Z] Event: Image removal {"image":{"name":"registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824","appId":738415,"serviceId":2092,"serviceName":"main","imageId":365929,"releaseId":536884,"dependent":0}}
[2018-07-15T04:35:22.178Z] Event: Image removed {"image":{"name":"registry2.resin.io/v2/c380f7859f3bc7ab3f478a112b70e9f7@sha256:c6b22b07cc97a400fc2b4f682f578862dd1b9548a18a7ea584e25576be682824","appId":738415,"serviceId":2092,"serviceName":"main","imageId":365929,"releaseId":536884,"dependent":0}}
[2018-07-15T04:35:22.853Z] Event: Service install {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.supervised":"true","io.resin.app-id":"738415","io.resin.service-id":"2092","io.resin.service-name":"main"}}}
[2018-07-15T04:35:23.149Z] Event: Service installed {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.supervised":"true","io.resin.app-id":"738415","io.resin.service-id":"2092","io.resin.service-name":"main"}}}
[2018-07-15T04:35:23.177Z] Event: Service start {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.supervised":"true","io.resin.app-id":"738415","io.resin.service-id":"2092","io.resin.service-name":"main"}}}
[2018-07-15T04:35:25.094Z] Event: Service started {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.supervised":"true","io.resin.app-id":"738415","io.resin.service-id":"2092","io.resin.service-name":"main"}}}
[2018-07-15T04:35:25.802Z] Finished applying target state
[2018-07-15T04:35:25.810Z] Apply success!
[2018-07-15T07:39:11.627Z] Event: Update notification {}
[2018-07-15T07:39:58.737Z] Event: Update notification {}
[2018-07-15T07:47:24.302Z] Event: Update notification {}
[2018-07-15T07:47:26.488Z] Event: Update notification {}
[2018-07-15T07:48:26.443Z] Event: Update notification {}
[2018-07-15T07:48:34.510Z] Event: Update notification {}
[2018-07-15T07:48:41.804Z] Event: Update notification {}
[2018-07-15T07:48:49.022Z] Applying target state
[2018-07-15T07:48:49.723Z] Event: Service kill {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.app-id":"738415","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.service-id":"2092","io.resin.service-name":"main","io.resin.supervised":"true"}}}
[2018-07-15T07:49:00.963Z] Event: Service exit {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.app-id":"738415","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.service-id":"2092","io.resin.service-name":"main","io.resin.supervised":"true"}}}
[2018-07-15T07:49:01.097Z] Event: Service stop {"service":{"appId":738415,"serviceId":2092,"serviceName":"main","releaseId":537738,"image":"sha256:17fc3966d0221aa7a0343840d26405054c54d8bccd1fcf6fe64f501dcc800689","labels":{"io.resin.app-id":"738415","io.resin.architecture":"armv7hf","io.resin.device-type":"raspberry-pi2","io.resin.features.dbus":"1","io.resin.features.firmware":"1","io.resin.features.kernel-modules":"1","io.resin.features.resin-api":"1","io.resin.features.supervisor-api":"1","io.resin.qemu.version":"2.9.0.resin1-arm","io.resin.service-id":"2092","io.resin.service-name":"main","io.resin.supervised":"true"}}}
[2018-07-15T07:49:01.551Z] Event: Image removal {"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0}}
[2018-07-15T07:49:10.822Z] Event: Image removed {"image":{"name":"registry2.resin.io/v2/e5645a1694688aeb7b5a0233295e1d44@sha256:61b23c5ed62a84b3c8c3089655a99cc7034b9fe4251d169d670f28fecd5f8bb5","appId":738415,"serviceId":2092,"serviceName":"main","imageId":367029,"releaseId":537738,"dependent":0}}
[2018-07-15T07:49:11.355Z] Event: Volume removal {}
[2018-07-15T07:49:11.998Z] Finished applying target state
[2018-07-15T07:49:12.001Z] Apply success!
