ok got into it by ssh’ing into 22222. i can ping the outside so not sure why it can’t talk to resin.io.
please let me know what you would like to to check.
looks like resin_supervisor is running. i connected to that container and i can ping outside as well.
here is the log from that container.
init started: BusyBox v1.24.1 (2017-07-25 03:42:19 UTC)
starting pid 11, tty '/dev/stdout': '/usr/src/app/entry.sh'
starting pid 14, tty '/dev/stdout': '/usr/src/app/run.sh node /usr/src/app/dist/app.js'
starting pid 15, tty '/dev/stdout': '/usr/src/app/run.sh /usr/src/app/gosuper'
2017/08/11 00:32:53 main.go:65: Resin Go Supervisor starting
2017/08/11 00:32:53 main.go:45: Changing oom_score_adj for the supervisor container to -800
2017/08/11 00:32:53 main.go:50: Changing oom_score_adj for openvpn and connmand to -1000 if 0, every 5 minutes
2017/08/11 00:32:54 main.go:35: Starting HTTP server on /var/run/resin/gosuper.sock
[2017-08-11T00:32:56.875Z] Knex:warning - sqlite does not support inserting default values. Set the `useNullAsDefault` flag to hide this warning. (see docs http://knexjs.org/#Builder-insert).
[2017-08-11T00:32:57.830Z] Event: Supervisor start {}
[2017-08-11T00:32:57.842Z] Starting connectivity check..
Fri, 11 Aug 2017 00:32:58 GMT body-parser deprecated bodyParser: use individual json/urlencoded middlewares at eval at <anonymous> (/usr/src/app/dist/app.js:294:80836), <anonymous>:14:44
Fri, 11 Aug 2017 00:32:58 GMT body-parser deprecated undefined extended: provide extended option at eval at wrapfunction (/usr/src/app/dist/app.js:1:120477), <anonymous>:4:11
[2017-08-11T00:32:58.225Z] Starting API server..
[2017-08-11T00:32:58.227Z] Starting Apps..
[2017-08-11T00:32:58.256Z] Starting periodic check for IP addresses..
[2017-08-11T00:32:58.265Z] Updating supervisor version and api info
[2017-08-11T00:32:58.321Z] Event: Start application update poll {"interval":60000}
Fri, 11 Aug 2017 00:32:58 GMT body-parser deprecated bodyParser: use individual json/urlencoded middlewares at usr/src/app/dist/app.js:92:29127
[2017-08-11T00:32:58.579Z] Internet Connectivity: OK
[2017-08-11T00:52:25.477Z] Waiting for connectivity...
[2017-08-11T00:52:35.514Z] Internet Connectivity: OK
Hi again,
To be honest, we are a bit unsure why your device is not provisioning. To be able to debug this further we need to get into the device which we can do by jumping through another device on the network. To enable us to do this, please can you:
- Leave the NUC provisioned, powered up and connected to the network. PM the UUID if it has changed.
- Leave an RPi, provisioned, powered up and connected to the same network. PM the UUID.
This will allow us to SSH into the RPi and from there, connect to the NUC to debug.
Either @flesler (19.00 - 22.00 UTC) or @brownjohnf (22.00 - 24.00 UTC) will be on support later on and should be able to help you
