I am trying to install PyICU in to a Balena container. The container I am using is:
balenalib/%%BALENA_ARCH%%-debian-python:3.8.10-buster-20210506
The container already has Python installed in to /usr/local/bin/python3:
# which python3
I then run the install command for PyICU:
install_packages python3-icu
Which gives the following output:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
libexpat1 libicu63 libmpdec2 libpython3-stdlib libpython3.7-minimal libpython3.7-stdlib mime-support python3
python3-minimal python3.7 python3.7-minimal
Suggested packages:
python3-doc python3-tk python3-venv python3.7-venv python3.7-doc binutils binfmt-support
Recommended packages:
bzip2 file xz-utils
The following NEW packages will be installed:
libexpat1 libicu63 libmpdec2 libpython3-stdlib libpython3.7-minimal libpython3.7-stdlib mime-support python3 python3-icu
0 upgraded, 12 newly installed, 0 to remove and 27 not upgraded.
Need to get 12.7 MB of archives.
Because Balena images have Python installed in /usr/local/bin/ rather than /usr/bin, it is fetching Python again and installing it again through the package manager. Of course I would like to try and avoid this as it is adding extra size to my images. Any ideas how? Ideally without having to build PyICU or other packages from source.
