Initial repo push failed "[remote rejected] master -> master (hook declined)"
I cloned the repo https://github.com/jpmeijers/ttn-resin-gateway-rpi.git onto my local machine and then attempted to push it up to my balena repo. It errored-out.
Here’s part of output:
git push balena
Counting objects: 741, done.
Delta compression using up to 8 threads.
Compressing objects: 100% (312/312), done.
Writing objects: 100% (741/741), 3.27 MiB | 1.48 MiB/s, done.
Total 741 (delta 414), reused 741 (delta 414)
remote: Resolving deltas: 100% (414/414), done.
[main] Fetched 23.6 MB in 13s (1785 kB/s)
[main] W: Failed to fetch http://deb.debian.org/debian/dists/jessie-updates/main/binary-armhf/Packages 404 Not Found
[main] E: Some index files failed to download. They have been ignored, or old ones used instead.
[main]
[main] Removing intermediate container 1d54fc0f4d7e
[main] The command ‘/bin/sh -c apt-get update && apt-get install wget build-essential libc6-dev git pkg-config protobuf-compiler libprotobuf-dev libprotoc-dev automake libtool autoconf python-dev python-rpi.gpio’ returned a non-zero code: 100
[Info] Uploading images
[Error] Service: main
[Error] Error: The command ‘/bin/sh -c apt-get update && apt-get install wget build-essential libc6-dev git pkg-config protobuf-compiler libprotobuf-dev libprotoc-dev automake libtool autoconf python-dev python-rpi.gpio’ returned a non-zero code: 100
To git.balena-cloud.com:willie_witten/lorawangw.git
! [remote rejected] master -> master (hook declined)
error: failed to push some refs to ‘willie_witten@git.balena-cloud.com:willie_witten/lorawangw.git’
There is more output, unfortunately since I am a “new user” I can’t put in all of the output as apparently I can only put in 5 links as a “new user.” The posting mechanism is interpreting the output as links.
It seemed pretty straightforward…I don’t know how to fix this.
