I’m using a BalenaFin, running kernel 4.19.71.
Linux 95a5b00 4.19.71 #1 SMP Wed Jan 15 20:59:27 UTC 2020 armv7l GNU/Linux
I’m starting with the python3 container:
FROM balenalib/%%BALENA_MACHINE_NAME%%-python:3-stretch-run
Running “pip3 install awsiotsdk” (v2 of API) or “pip3 install AWSIoTPythonSDK” (v1 of API) results in a lengthy error message which centers around “ImportError: No module named ‘pkg_resources.py31compat’”.
This breaks when pushing the container, and also breaks when entered by hand in the terminal. Strangely, running the command a 2nd time works correctly. However, this can not be used in an automated deployment.
I have found a few posts out there for similar error messages, but they haven’t helped.
e.g. https://stackoverflow.com/questions/46998858/importerror-no-module-named-py31compat
Has anyone got any ideas how to install the sdk without creating this error? Thank you!
Here are transcripts of running the commands in the CLI:
API v1:
root@95a5b00:/usr/src/app/src/acoustic# pip3 install AWSIoTPythonSDK
Collecting AWSIoTPythonSDK
Downloading AWSIoTPythonSDK-1.4.8.tar.gz (80 kB)
|████████████████████████████████| 80 kB 1.0 MB/s
Using legacy setup.py install for AWSIoTPythonSDK, since package 'wheel' is not installed.
Installing collected packages: AWSIoTPythonSDK
Running setup.py install for AWSIoTPythonSDK ... error
ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python3.5 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-w5y6qx9f/AWSIoTPythonSDK/setup.py'"'"'; __file__='"'"'/tmp/pip-install-w5y6qx9f/AWSIoTPythonSDK/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-v7n09v8i/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.5m/AWSIoTPythonSDK
cwd: /tmp/pip-install-w5y6qx9f/AWSIoTPythonSDK/
Complete output (165 lines):
running install
running build
running build_py
creating build
creating build/lib
creating build/lib/AWSIoTPythonSDK
copying AWSIoTPythonSDK/__init__.py -> build/lib/AWSIoTPythonSDK
copying AWSIoTPythonSDK/MQTTLib.py -> build/lib/AWSIoTPythonSDK
creating build/lib/AWSIoTPythonSDK/core
copying AWSIoTPythonSDK/core/__init__.py -> build/lib/AWSIoTPythonSDK/core
creating build/lib/AWSIoTPythonSDK/core/util
copying AWSIoTPythonSDK/core/util/__init__.py -> build/lib/AWSIoTPythonSDK/core/util
copying AWSIoTPythonSDK/core/util/enums.py -> build/lib/AWSIoTPythonSDK/core/util
copying AWSIoTPythonSDK/core/util/providers.py -> build/lib/AWSIoTPythonSDK/core/util
creating build/lib/AWSIoTPythonSDK/core/shadow
copying AWSIoTPythonSDK/core/shadow/deviceShadow.py -> build/lib/AWSIoTPythonSDK/core/shadow
copying AWSIoTPythonSDK/core/shadow/__init__.py -> build/lib/AWSIoTPythonSDK/core/shadow
copying AWSIoTPythonSDK/core/shadow/shadowManager.py -> build/lib/AWSIoTPythonSDK/core/shadow
creating build/lib/AWSIoTPythonSDK/core/protocol
copying AWSIoTPythonSDK/core/protocol/mqtt_core.py -> build/lib/AWSIoTPythonSDK/core/protocol
copying AWSIoTPythonSDK/core/protocol/__init__.py -> build/lib/AWSIoTPythonSDK/core/protocol
creating build/lib/AWSIoTPythonSDK/core/jobs
copying AWSIoTPythonSDK/core/jobs/__init__.py -> build/lib/AWSIoTPythonSDK/core/jobs
copying AWSIoTPythonSDK/core/jobs/thingJobManager.py -> build/lib/AWSIoTPythonSDK/core/jobs
creating build/lib/AWSIoTPythonSDK/core/protocol/paho
copying AWSIoTPythonSDK/core/protocol/paho/__init__.py -> build/lib/AWSIoTPythonSDK/core/protocol/paho
copying AWSIoTPythonSDK/core/protocol/paho/client.py -> build/lib/AWSIoTPythonSDK/core/protocol/paho
creating build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/queues.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/workers.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/defaults.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/clients.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/__init__.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/events.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
copying AWSIoTPythonSDK/core/protocol/internal/requests.py -> build/lib/AWSIoTPythonSDK/core/protocol/internal
creating build/lib/AWSIoTPythonSDK/core/protocol/connection
copying AWSIoTPythonSDK/core/protocol/connection/__init__.py -> build/lib/AWSIoTPythonSDK/core/protocol/connection
copying AWSIoTPythonSDK/core/protocol/connection/cores.py -> build/lib/AWSIoTPythonSDK/core/protocol/connection
copying AWSIoTPythonSDK/core/protocol/connection/alpn.py -> build/lib/AWSIoTPythonSDK/core/protocol/connection
creating build/lib/AWSIoTPythonSDK/core/greengrass
copying AWSIoTPythonSDK/core/greengrass/__init__.py -> build/lib/AWSIoTPythonSDK/core/greengrass
creating build/lib/AWSIoTPythonSDK/core/greengrass/discovery
copying AWSIoTPythonSDK/core/greengrass/discovery/__init__.py -> build/lib/AWSIoTPythonSDK/core/greengrass/discovery
copying AWSIoTPythonSDK/core/greengrass/discovery/providers.py -> build/lib/AWSIoTPythonSDK/core/greengrass/discovery
copying AWSIoTPythonSDK/core/greengrass/discovery/models.py -> build/lib/AWSIoTPythonSDK/core/greengrass/discovery
creating build/lib/AWSIoTPythonSDK/exception
copying AWSIoTPythonSDK/exception/operationTimeoutException.py -> build/lib/AWSIoTPythonSDK/exception
copying AWSIoTPythonSDK/exception/operationError.py -> build/lib/AWSIoTPythonSDK/exception
copying AWSIoTPythonSDK/exception/__init__.py -> build/lib/AWSIoTPythonSDK/exception
copying AWSIoTPythonSDK/exception/AWSIoTExceptions.py -> build/lib/AWSIoTPythonSDK/exception
running install_lib
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception
copying build/lib/AWSIoTPythonSDK/exception/operationTimeoutException.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception
copying build/lib/AWSIoTPythonSDK/exception/operationError.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception
copying build/lib/AWSIoTPythonSDK/exception/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception
copying build/lib/AWSIoTPythonSDK/exception/AWSIoTExceptions.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util
copying build/lib/AWSIoTPythonSDK/core/util/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util
copying build/lib/AWSIoTPythonSDK/core/util/enums.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util
copying build/lib/AWSIoTPythonSDK/core/util/providers.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow
copying build/lib/AWSIoTPythonSDK/core/shadow/deviceShadow.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow
copying build/lib/AWSIoTPythonSDK/core/shadow/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow
copying build/lib/AWSIoTPythonSDK/core/shadow/shadowManager.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection
copying build/lib/AWSIoTPythonSDK/core/protocol/connection/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection
copying build/lib/AWSIoTPythonSDK/core/protocol/connection/cores.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection
copying build/lib/AWSIoTPythonSDK/core/protocol/connection/alpn.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection
copying build/lib/AWSIoTPythonSDK/core/protocol/mqtt_core.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol
copying build/lib/AWSIoTPythonSDK/core/protocol/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/queues.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/workers.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/defaults.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/clients.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/events.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
copying build/lib/AWSIoTPythonSDK/core/protocol/internal/requests.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/paho
copying build/lib/AWSIoTPythonSDK/core/protocol/paho/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/paho
copying build/lib/AWSIoTPythonSDK/core/protocol/paho/client.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/paho
copying build/lib/AWSIoTPythonSDK/core/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass
copying build/lib/AWSIoTPythonSDK/core/greengrass/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery
copying build/lib/AWSIoTPythonSDK/core/greengrass/discovery/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery
copying build/lib/AWSIoTPythonSDK/core/greengrass/discovery/providers.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery
copying build/lib/AWSIoTPythonSDK/core/greengrass/discovery/models.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery
creating /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/jobs
copying build/lib/AWSIoTPythonSDK/core/jobs/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/jobs
copying build/lib/AWSIoTPythonSDK/core/jobs/thingJobManager.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/jobs
copying build/lib/AWSIoTPythonSDK/__init__.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK
copying build/lib/AWSIoTPythonSDK/MQTTLib.py -> /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception/operationTimeoutException.py to operationTimeoutException.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception/operationError.py to operationError.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/exception/AWSIoTExceptions.py to AWSIoTExceptions.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util/enums.py to enums.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/util/providers.py to providers.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow/deviceShadow.py to deviceShadow.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/shadow/shadowManager.py to shadowManager.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection/cores.py to cores.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/connection/alpn.py to alpn.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/mqtt_core.py to mqtt_core.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/queues.py to queues.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/workers.py to workers.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/defaults.py to defaults.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/clients.py to clients.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/events.py to events.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/internal/requests.py to requests.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/paho/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/protocol/paho/client.py to client.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery/providers.py to providers.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/greengrass/discovery/models.py to models.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/jobs/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/core/jobs/thingJobManager.py to thingJobManager.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK/MQTTLib.py to MQTTLib.cpython-35.pyc
running install_egg_info
running egg_info
creating AWSIoTPythonSDK.egg-info
writing dependency_links to AWSIoTPythonSDK.egg-info/dependency_links.txt
writing AWSIoTPythonSDK.egg-info/PKG-INFO
writing top-level names to AWSIoTPythonSDK.egg-info/top_level.txt
writing manifest file 'AWSIoTPythonSDK.egg-info/SOURCES.txt'
reading manifest file 'AWSIoTPythonSDK.egg-info/SOURCES.txt'
Copying AWSIoTPythonSDK.egg-info to /usr/local/lib/python3.5/site-packages/AWSIoTPythonSDK-1.4.8-py3.5.egg-info
running install_scripts
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-install-w5y6qx9f/AWSIoTPythonSDK/setup.py", line 32, in <module>
"Programming Language :: Python :: 3.5"
File "/usr/local/lib/python3.5/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/local/lib/python3.5/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python3.5/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/usr/local/lib/python3.5/site-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/usr/local/lib/python3.5/distutils/command/install.py", line 551, in run
self.run_command(cmd_name)
File "/usr/local/lib/python3.5/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/local/lib/python3.5/site-packages/setuptools/command/install_scripts.py", line 17, in run
import setuptools.command.easy_install as ei
File "/usr/local/lib/python3.5/site-packages/setuptools/command/easy_install.py", line 52, in <module>
from setuptools.sandbox import run_setup
File "/usr/local/lib/python3.5/site-packages/setuptools/sandbox.py", line 15, in <module>
import pkg_resources.py31compat
ImportError: No module named 'pkg_resources.py31compat'
ERROR: Command errored out with exit status 1: /usr/local/bin/python3.5 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-w5y6qx9f/AWSIoTPythonSDK/setup.py'"'"'; __file__='"'"'/tmp/pip-install-w5y6qx9f/AWSIoTPythonSDK/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-v7n09v8i/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.5m/AWSIoTPythonSDK Check the logs for full command output.
And Here is with V2:
(note, i have snipped a large amount of the compiling in order to fit this post here!)
root@95a5b00:/usr/src/app/src/acoustic# pip3 install awsiotsdk
Collecting awsiotsdk
Using cached awsiotsdk-1.1.0-py2.py3-none-any.whl (18 kB)
Collecting awscrt==0.5.15
Using cached awscrt-0.5.15.tar.gz (2.0 MB)
Using legacy setup.py install for awscrt, since package 'wheel' is not installed.
Installing collected packages: awscrt, awsiotsdk
Running setup.py install for awscrt ... error
command: /usr/local/bin/python3.5 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-u13pr5k5/awscrt/setup.py'"'"'; __file__='"'"'/tmp/pip-install-u13pr5k5/awscrt/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-acn51f1t/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.5m/awscrt
cwd: /tmp/pip-install-u13pr5k5/awscrt/
Complete output (898 lines):
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/awscrt
copying awscrt/http.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/mqtt.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/auth.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/__init__.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/crypto.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/awsiot_mqtt_connection_builder.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/io.py -> build/lib.linux-armv7l-3.5/awscrt
copying awscrt/exceptions.py -> build/lib.linux-armv7l-3.5/awscrt
running build_ext
cmake version 3.7.2
(snip to fit post on forum)
gcc -pthread -shared build/temp.linux-armv7l-3.5/source/http_stream.o build/temp.linux-armv7l-3.5/source/mqtt_client_connection.o build/temp.linux-armv7l-3.5/source/io.o build/temp.linux-armv7l-3.5/source/http_proxy.o build/temp.linux-armv7l-3.5/source/http_message.o build/temp.linux-armv7l-3.5/source/auth_signing_config.o build/temp.linux-armv7l-3.5/source/auth_signer.o build/temp.linux-armv7l-3.5/source/module.o build/temp.linux-armv7l-3.5/source/http_connection.o build/temp.linux-armv7l-3.5/source/auth_credentials.o build/temp.linux-armv7l-3.5/source/crypto.o build/temp.linux-armv7l-3.5/source/mqtt_client.o build/temp.linux-armv7l-3.5/source/http_headers.o -L/usr/local/lib -L/tmp/pip-install-u13pr5k5/awscrt/build/deps/install/lib -laws-c-mqtt -laws-c-auth -laws-c-http -laws-c-compression -laws-c-cal -laws-c-io -laws-c-common -ls2n -l:libcrypto.a -lrt -lpython3.5m -o build/lib.linux-armv7l-3.5/_awscrt.cpython-35m-arm-linux-gnueabihf.so
running install_lib
creating /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/http.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/mqtt.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/auth.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/__init__.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/crypto.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/awsiot_mqtt_connection_builder.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/io.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/awscrt/exceptions.py -> /usr/local/lib/python3.5/site-packages/awscrt
copying build/lib.linux-armv7l-3.5/_awscrt.cpython-35m-arm-linux-gnueabihf.so -> /usr/local/lib/python3.5/site-packages
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/http.py to http.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/mqtt.py to mqtt.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/auth.py to auth.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/__init__.py to __init__.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/crypto.py to crypto.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/awsiot_mqtt_connection_builder.py to awsiot_mqtt_connection_builder.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/io.py to io.cpython-35.pyc
byte-compiling /usr/local/lib/python3.5/site-packages/awscrt/exceptions.py to exceptions.cpython-35.pyc
running egg_info
writing awscrt.egg-info/PKG-INFO
writing requirements to awscrt.egg-info/requires.txt
writing dependency_links to awscrt.egg-info/dependency_links.txt
writing top-level names to awscrt.egg-info/top_level.txt
reading manifest file 'awscrt.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '.git*/**' found anywhere in distribution
warning: no previously-included files matching '.travis*' found anywhere in distribution
warning: no previously-included files matching '.travis/**' found anywhere in distribution
warning: no previously-included files matching 'codebuild/**' found anywhere in distribution
warning: no previously-included files matching '.cbmc-batch/**' found anywhere in distribution
warning: no previously-included files matching 'aws-common-runtime/*/docs/**' found anywhere in distribution
warning: no previously-included files matching 'docker-images/**' found anywhere in distribution
no previously-included directories found matching 'aws-common-runtime/aws-c-auth/tests/aws-sig-v4-test-suite'
no previously-included directories found matching 'aws-common-runtime/aws-c-auth/tests/fuzz/corpus'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/fuzz/corpus'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/ctverif'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/pems'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/saw'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/sidetrail'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/integration/trust-store'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/integration/data'
no previously-included directories found matching 'aws-common-runtime/s2n/tests/unit/kats'
writing manifest file 'awscrt.egg-info/SOURCES.txt'
Copying awscrt.egg-info to /usr/local/lib/python3.5/site-packages/awscrt-0.5.15-py3.5.egg-info
File "/tmp/pip-install-u13pr5k5/awscrt/setup.py", line 267, in <module>
'boto3'
File "/usr/local/lib/python3.5/site-packages/setuptools/__init__.py", line 144, in setup
return distutils.core.setup(**attrs)
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
ERROR: Command errored out with exit status 1: /usr/local/bin/python3.5 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-u13pr5k5/awscrt/setup.py'"'"'; __file__='"'"'/tmp/pip-install-u13pr5k5/awscrt/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-acn51f1t/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.5m/awscrt Check the logs for full command output.
