jayden
1
Hey there, hoping someone can help me get my touchscreen to work.
The screen itself is the SunFounder 10.1’’ Touch Screen, which plugs in via USB. The screen works fine on Raspbian.
From what I have been able to find, the chip is an Ilitek ili251x (ili2511QG010 to be exact).
Any help at all would be appreciated.
Hi @jayden,
Can you paste here the output of lsusb with your touchscreen connected and without it connected?
This way we can see what driver would be needed for it to work.
Regards!
jayden
5
Thank you so much @spanceac,
The device shows up in lsusb as the following, which isn’t very helpful.
Bus 001 Device 004: ID 222a:0001
So hopefully the results of lsusb -D /dev/bus/usb/001/004 are more helpful to you:
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x222a
idProduct 0x0001
bcdDevice 0.00
iManufacturer 1 ILITEK
iProduct 2 ILITEK-TP
iSerial 3 V06.00.00.00
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 59
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 400mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 743
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
wDescriptorLength 107
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
Hi @jayden,
This device seems to be supported by the hid-multitouch kernel driver.
When you plug the touchscreen you should see with lsmod that the driver is loaded.
A /dev/input/ entry should be created when you plug the device and your application should know how to parse the touchscreen data.
