How to do docker pull into balena os raspberry pi W Zero?
Hi guys , I got a docker image, how do I pull it now into my device ? It’s already running and I can see it within Dashboard. Whats the command?
Hello, you typically don’t pull a Docker image manually on the device. You may want to go through our Getting Started guide to get a sense of how it all works: https://www.balena.io/docs/learn/getting-started/raspberrypi3/nodejs/
