Hi everyone,
I have a IOT2000 (x86 based) device running with Balena OS. I have a balenalib/iot2000-ubuntu image on local PC. I have downloaded some dependencies and compiled some code on it which runs correctly.
I saved this container as a new image. I also have it available on my docker hub account.
I want to push this container on the device running Balena OS now and see if it works there. I have read, this is a wrong way of generating Docker Images, but I need to quickly try if my code can run on the hardware.
What should be the steps to achieve this? I believe it has something to do with https://www.balena.io/docs/reference/base-images/custom-docker-base-images/ but I am not sure what are the exact steps once that is done.
Also, once this is achieved will my compiled code and libraries be available to use directly on my device container? A little bit confused here. I want to avoid all the building and compiling of the code on the device.
Update: I made a dockerfile in a folder as following:
FROM repository name
CMD [“bash”]
I went to this folder and did a sudo balena push
Would this be a correct way to do it?
Thanks for your help
Hey @controlsgeek, It seems like you have figured it out, but basically there 2 ways to do it. you can either do it from a single container using Dockerile like this:
FROM shaunmulligan/myPrivateImage
CMD ["bash", "run-something.sh"]
or from a docker-compose.yml in multicontainer like so:
version: '2'
services:
frontend:
image: shaunmulligan/myPrivateImage
Thanks @shaunmulligan. I was attempting to do that, but I kept getting the following error:
[Could not communicate with local mode device]. I am able to ping the device at that IP and also ssh into it.
I have the device in my Balena dashboard, and switched to ‘local mode’.
Does the Resin OS 2.12.7+rev2 dev not support local mode yet ?
What would be an alternative method to push this image?
Ah @controlsgeek unfortunately its probably due to your device OS version not meeting the minimum OS requirements for balena push <IP>, take a look here https://www.balena.io/docs/learn/develop/local-mode/#local-mode-requirements .
What device type are you working on?
I am using the Siemens IOT2000 board.
Do I have to push it through git if the local mode doesn’t work?
Yes, pushing through git should do the job.
Thanks @samothx. I will try this soon and will update the thread if I was successful in creating a container on IOT2000.
@shaunmulligan @samothx
I was able to download my container through git to IOT2000. But the container kept starting, exiting and restarting.
Running the container as “docker run imagename” works correctly on my PC and does not exit.
The original image I used was “balenalib/iot2000-ubuntu”.
I ssh’ed into this image on my PC, and compiled some libraries and committed this image as a new image.
I built a dockerfile which then used this image in “FROM” and runs a script present inside the image. This dockerfile was used to build the image through balena and upload on IOT2000.
Is there anything wrong with this process that is should not work? When on PC running uname inside the container I get x86_84 for machine, processor and hardware platform. Whereas uname inside balena OS on IOT 2000, I get i586 for machine and processor, and i386 for hardware platform.
Should the balenalib/iot2000-ubuntu image work correctly on IOT2000 without any issue?
Thanks for all your help.
Hi @controlsgeek,
you are trying to create a i386 image on a arm64 / x86_64 platform, so what you are attempting is basically to create an image for a different platform on your pc.
You could use something like the linux file command inside the container to check what platform your binaries are compiled for, example:
file /bin/cp
/bin/cp: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/l, for GNU/Linux 3.2.0, BuildID[sha1]=9720743c3b9fbf61b6f38b7568c10a6dbed05a61, stripped
Can you also share the Dockerfile you use to create that image ?
Regards
Thomas
@samothx
The dockerfile which I had used was:
FROM controlsgeek/iot2000_pyfmi
WORKDIR "/home/JModelica/bin"
ENTRYPOINT "./test.sh"
CMD ["tail", "-f", "/dev/null"]
where controlsgeek/iot2000_pyfmi was the image generated by ssh’ing into “balenalib/iot2000-ubuntu”, installing everything and then “docker commit” it as “controlsgeek/iot2000_pyfmi”
I thought since I am deriving my image from i386 ubuntu container, it shouldn’t matter.
I just made a new Dockerfile which does all the installation:
FROM balenalib/iot2000-ubuntu:xenial
RUN apt-get update
RUN apt-get install -y --no-install-recommends \
less \
kmod \
nano \
net-tools \
ifupdown \
iputils-ping \
i2c-tools \
usbutils \
g++ \
subversion \
gfortran \
ipython \
cmake \
swig \
ant \
openjdk-8-jdk \
python-dev \
python-numpy \
python-scipy \
python-matplotlib \
cython \
python-lxml \
python-nose \
python-jpype \
zlib1g-dev \
libboost-dev \
COPY JModelica.org /home/JModelica.org
RUN apt-get update && apt-get install make
WORKDIR /home/JModelica.org
RUN rm -rf build
RUN mkdir build
WORKDIR /home/JModelica.org/build
RUN ../configure --prefix=/home/JModelica --disable-openmp
RUN make install
COPY test.fmu /home/JModelica/bin
COPY testfmu.py /home/JModelica/bin
COPY test.sh /home/JModelica/bin
Do you think this will work correctly when I do a “git push balena master” ?
Hi @controlsgeek,
I think that your new docker file should work fine.
Did you had the occasion to push it? Did it work?
Hi @spanceac
I tried to push it, but I having an error during build (make error), which I did not encounter on my local PC. I am trying to find the issue. Any hints?
Hi @controlsgeek,
You could paste the errors here and maybe we will have some ideas
This is the build error from Balena server. But it works perfectly on my PC. So I was not sure if it was some mistake with the settings.
[main] ---> c7d947e1b6c3
[main] Removing intermediate container 0b4a54b224f6
[main] Step 11/17 : RUN make install
[main] ---> Running in 4b697d71c0a5
[main] Making install in ThirdParty/winpthreads
[main] make[1]: Entering directory '/home/JModelica.org/build/ThirdParty/winpthreads'
[main] mkdir -p ../../winpthreads_build && \
[main] cd ../../winpthreads_build
[main] cp -r /home/JModelica.org/build/../ThirdParty/winpthreads/winpthreads/* /home/JModelica.org/build/ThirdParty/winpthreads/../../winpthreads_build/
[main] case x86_64-unknown-linux-gnu in \
[main] *-cygwin*|*-mingw*) \
[main] cd ../../winpthreads_build && ./configure && make CFLAGS=-m32 LDFLAGS=-m32 RCFLAGS='-F pe-i386' DESTDIR= && make CFLAGS=-m32 LDFLAGS=-m32 RCFLAGS='-F pe-i386' DESTDIR= ;; \
[main] esac
[main] make[2]: Entering directory '/home/JModelica.org/build/ThirdParty/winpthreads'
[main] make[2]: Nothing to be done for 'install-exec-am'.
[main] make[2]: Nothing to be done for 'install-data-am'.
[main] make[2]: Leaving directory '/home/JModelica.org/build/ThirdParty/winpthreads'
[main] make[1]: Leaving directory '/home/JModelica.org/build/ThirdParty/winpthreads'
[main] Making install in ThirdParty/SuperLU
[main] make[1]: Entering directory '/home/JModelica.org/build/ThirdParty/SuperLU'
[main] mkdir -p ../../superlu_build && \
[main] cd ../../superlu_build
[main] cp -r /home/JModelica.org/build/../ThirdParty/SuperLU/superlu_mt_3.1/* /home/JModelica.org/build/ThirdParty/SuperLU/../../superlu_build/
[main] cd ../../superlu_build && make blaslib EXTRA_CFLAGS=-m32 DESTDIR= && make superlulib EXTRA_CFLAGS=-m32 DESTDIR= ;; \
[main] *-apple*) \
[main] cd ../../superlu_build && make blaslib DESTDIR= && make superlulib DESTDIR= ;; \
[main] *) \
[main] esac
[main] make[2]: Entering directory '/home/JModelica.org/build/superlu_build'
[main] ( cd CBLAS; make )
[main] make[3]: Entering directory '/home/JModelica.org/build/superlu_build/CBLAS'
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c isamax.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c sasum.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c saxpy.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c scopy.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c sdot.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c snrm2.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c srot.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c sscal.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c sgemv.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c ssymv.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c strsv.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c sger.c
[main] gcc -D__OPENMP -g -O3 -fPIC -DAdd_ -I../SRC -c ssyr2.c
[main] ar cr ../lib/libblas_OPENMP.a isamax.o sasum.o saxpy.o scopy.o sdot.o snrm2.o srot.o sscal.o \
[main] sgemv.o ssymv.o strsv.o sger.o ssyr2.o
[main] ar: ../lib/libblas_OPENMP.a: No such file or directory
[main] make[3]: *** [single] Error 1
[main]
[main] Makefile:67: recipe for target 'single' failed
[main] make[3]: Leaving directory '/home/JModelica.org/build/superlu_build/CBLAS'
[main] Makefile:30: recipe for target 'blaslib' failed
[main] make[2]: Leaving directory '/home/JModelica.org/build/superlu_build'
[main] make[2]: *** [blaslib] Error 2
[main]
[main] make[1]: *** [all-local] Error 2
[main]
[main] Makefile:421: recipe for target 'all-local' failed
[main] make[1]: Leaving directory '/home/JModelica.org/build/ThirdParty/SuperLU'
[main] Makefile:434: recipe for target 'install-recursive' failed
[main] make: *** [install-recursive] Error 1
[main]
[main] Removing intermediate container 4b697d71c0a5
[Info] Uploading images
[main] The command '/bin/sh -c make install' returned a non-zero code: 2
[Error] Service: main
[Error] Error: The command '/bin/sh -c make install' returned a non-zero code: 2
Hi @spanceac
I changed the docker file to use a pre compiled python package for testing,
RUN apt-get update
less \
kmod \
nano \
net-tools \
ifupdown \
iputils-ping \
i2c-tools \
usbutils \
python-dev \
python-numpy \
python-scipy \
RUN apt-get update
WORKDIR /home
RUN curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
RUN python get-pip.py
RUN python -m pip install https://github.com/CATIA-Systems/FMPy/archive/develop.zip
COPY test1.sh /home/test.sh
COPY testfmu.py /home/testfmu.py
It did a successful “git push balena master” and the service was updated on the device but I still have the same issue.
This is what I see in logs. This keeps happening:
12.04.19 15:05:43 (-0400) Service exited 'main sha256:76ac62b87c297909b542c4f3e81727a49caa6a32a36ac693d9fcb7a8b733104b'
12.04.19 15:06:19 (-0400) Restarting service 'main sha256:76ac62b87c297909b542c4f3e81727a49caa6a32a36ac693d9fcb7a8b733104b'
12.04.19 15:06:23 (-0400) Service exited 'main sha256:76ac62b87c297909b542c4f3e81727a49caa6a32a36ac693d9fcb7a8b733104b'
12.04.19 15:07:23 (-0400) Restarting service 'main sha256:76ac62b87c297909b542c4f3e81727a49caa6a32a36ac693d9fcb7a8b733104b'
12.04.19 15:07:27 (-0400) Service exited 'main sha256:76ac62b87c297909b542c4f3e81727a49caa6a32a36ac693d9fcb7a8b733104b'
Update: 1
I ssh’ed into the device host and tried to see what is happening. I got ‘exit 132’. What must be going wrong here?
root@localhost:~# balena ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
62501c997d07 76ac62b87c29 "/bin/sh -c \"./tes..." About a minute ago Exited (132) About a minute ago sleepy_lamport
018f742402d4 resin/i386-nlp-supervisor:v7.4.3_logstream "./entry.sh" About an hour ago Up About an hour (healthy) resin_supervisor
Update 2
I pulled the “balenalib/iot2000-ubuntu:xenial” image in device and tried to run it in container. It exited with the same exit code. Shown below. I guess the image is somehow not compatible with the hardware. Any suggestions?
root@localhost:~# balena images
REPOSITORY TAG IMAGE ID CREATED SIZE
registry2.balena-cloud.com/v2/1d87e268c00d6aa99b4a63f4e9d20d97 <none> 76ac62b87c29 3 hours ago 424MB
balenalib/iot2000-ubuntu xenial ee0363828a88 3 days ago 190MB
resin/i386-nlp-supervisor v7.4.3_logstream 7e9f8dda1a9e 8 months ago 58.4MB
root@localhost:~# balena run --name ubuntu -it ee0363828a88 bash
e8525c36b324 ee0363828a88 "/usr/bin/entry.sh..." 15 seconds ago Exited (132) 6 seconds ago ubuntu
018f742402d4 resin/i386-nlp-supervisor:v7.4.3_logstream "./entry.sh" 2 hours ago Up 2 hours (healthy) resin_supervisor
If I switch on the Debug flag, it prints
DEBU[0011] [hijack] End of stdout
and logs is empty.
@controlsgeek, it sounds like the ubuntu base images are missing the adaptions that are needed to run on the i386-nlp CPU, I remember when we first supported this CPU it had a number of issues that had to be hacked around due to the CPU instruction Errata. @nghiant2710 do you know of any reason why the balenalib/iot2000-ubuntu:xenial base images errors out with exti 132 ?
You may want to check this, or this commits that resolves the error message you got.
