Hello @stratosb Today Edge Impulse pushed a PR on their repository and now it should work. Could you please check on 32 or 64 bits?
Keep us updated
Keep us updated
Ok, I will.
Thank you.
Hi @mpous,
I deployed again the EdgeImpulse ML Model on raspberry pi 3 with balena and works correctly.
It displays the three states I have specified: pair, unpair and unknown
Thank you
@mpous
Regarding the balenaOS version, the dashboard displays only the following three versions when adding a new device:
v2.58.3+rev1
v2.56.0+rev2
v2.51.1+rev1
So I donβt know which version is the 32-bit or 64-bit balenaOS.
For this project I chose the recommended version, which is v2.58.3+rev1
@mpous
If I wish to retrain the learning model with more pairs of socks, how can I deploy the new EdgeImpulse ML Model on the raspberry pi?
What I do now it to delete the device from the balena dashboard, download the new balenaOS image and flash it again to my SD card.
Is there a simpler and faster way to do it?
Thank you
@stratosb When you select the device architecture (e.g. Raspberry Pi 3 (32 bits)) then you select the compatible balenaOS versions and supervisor versions. You can see the recommended versions here https://balena-io.github.io/balenaosversions/
@stratosb as far as i know, you will need to reboot your device after retraining the model. Then automatically will download the latest version of the model to the device. Is it not working for you?
I will try it, thank you
