Deploys to my Raspberry Pi 4 (Raspberry Pi 4 (using 64bit OS) (BETA)) keep restarting…
If I deploy one image, all is ok, but when I try and deploy multiple images (including 1 large image), the upload of the image never completes, and just goes round and round in a loop uploading the image
Hi there, that sounds strange indeed, can you enable support access and share the UUID of the device with us? You can do it either in a PM or just paste it here. We will have a look at the logs and see what might be the cause of this.
Thanks - I will get a device setup that is reloading constantly for you (currently I have had to deploy by adding one image at a time)… and then send you the UUID…
Hi @walpoletim we’ve been taking a look at your device but it seems incredibly slow to navigate and look at log files. Do you have another SD card you could try?
We’ve run the diagnostic checks on your device and the check_write_latency check is failing, showing slow disk writes. Additionally there are the following errors seen when looking at dmesg:
[167355.950212] INFO: task kworker/2:3:6610 blocked for more than 120 seconds.
[167355.957749] Tainted: G C 4.19.66 #1
[167355.964054] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[167355.972792] kworker/2:3 D 0 6610 2 0x00000028
[167355.978810] Workqueue: events_freezable mmc_rescan
[167355.984161] Call trace:
[167355.987126] __switch_to+0xa8/0xe8
[167355.991862] __schedule+0x254/0x850
[167355.995572] schedule+0x38/0x98
[167355.998878] __mmc_claim_host+0xb8/0x200
[167356.002980] mmc_get_card+0x38/0x48
[167356.006632] mmc_sd_detect+0x24/0x90
[167356.010374] mmc_rescan+0xd0/0x370
[167356.013916] process_one_work+0x1ec/0x458
[167356.018115] worker_thread+0x48/0x430
[167356.021927] kthread+0x130/0x138
[167356.025351] ret_from_fork+0x10/0x1c
Give another SD card a try and let us know what happens, I hope this helps!
Can you please share which SD card make/model you are using? We recommend the Sandisk Extreme Pro sd cards.
I took a look at the device.
The balenaEngine healthcheck times out (in 6 minutes). This restarts the engine and the supervisor, which restarts the download.
The reason the balenaEngine healthcheck times out feels like a slow sd card.
e.g.
On a balenaFin (which is pi-cm3)
root@7ac2b83:~# time bash -x /usr/lib/balena/balena-healthcheck
+ set -o errexit
+ balena info
+ balena ps
+ balena run --rm --log-driver none --network none hello-world
real 0m3.959s
user 0m0.643s
sys 0m0.122s
root@7ac2b83:~#
The healthcheck is consistent and <5 seconds…
But on your device, the time can vary and go up quite a bit as well.
root@137e61a:~# time bash -x /usr/lib/balena/balena-healthcheck
+ set -o errexit
+ balena info
+ balena ps
real 0m30.664s
user 0m0.233s
sys 0m0.108s
+ set -o errexit
+ balena info
+ balena ps
real 0m1.853s
user 0m0.247s
sys 0m0.082s
+ set -o errexit
+ balena info
+ balena ps
real 0m1.870s
user 0m0.225s
sys 0m0.131s
+ set -o errexit
+ balena info
+ balena ps
real 0m1.898s
user 0m0.261s
sys 0m0.088s
root@137e61a:~#
+ set -o errexit
+ balena info
+ balena ps
real 0m1.868s
user 0m0.256s
sys 0m0.080s
+ set -o errexit
+ balena info
+ balena ps
real 0m12.315s
user 0m0.235s
sys 0m0.119s
+ set -o errexit
+ balena info
+ balena ps
real 0m14.328s
user 0m0.220s
sys 0m0.114s
+ set -o errexit
+ balena info
+ balena ps
real 0m8.249s
user 0m0.236s
sys 0m0.108s
root@137e61a:~#
The pi4 is pretty new and still going through various improvements. So it could be that a firmware bump fixes some sd card read/write. Or it could be the make/model of your sd cards.
At this point, I suspect it could be a pi4 firmware issue that I’m unaware off. Large network download was something that was being fixed. But I can’t remember when that fix went in
