When I do a “docker info” in the Host OS Or inside the container, it says
“docker: command not found”
Is there another way to get docker info??
Hi.
What kind of information are you interested in, more specifically?
Note that balenaOS uses a modified Docker daemon fork called balenaEngine. You can read more about the OS components here.
