Trying to get Homebridge working in a multi-container setup.
docker-compose.yml:
version: '2'
volumes:
homebridge:
services:
homebridge:
build: ./homebridge
privileged: true
restart: always
network_mode: host
volumes:
- 'homebridge:/'
environment:
- PGID=1000
- PUID=1000
mqtt:
image: panuwitp/mosquitto-arm
ports:
- '1883:1883'
pibell:
build: ./pibell
depends_on:
- mqtt
privileged: true
restart: always
And the homebridge Dockerfiles.template is:
FROM balenalib/%%BALENA_MACHINE_NAME%%-node
# use apt-get if you need to install dependencies,
# for instance if you need ALSA sound utils, just uncomment the lines below.
RUN apt-get update && apt-get install -yq \
git make python g++ nodejs avahi-daemon avahi-discover libnss-mdns \
libavahi-compat-libdnssd-dev && \
RUN /etc/init.d/dbus start
RUN /etc/init.d/avahi-daemon start
# Install homebridge
RUN npm install -g --unsafe-perm homebridge
RUN npm install -g --unsafe-perm homebridge-mqtt-switch-tasmota
# Copy config over
WORKDIR /root/.homebridge/
# Copy
COPY start.sh start.sh
COPY config.json config.json
# Execute permissions
RUN chmod +x start.sh
# Enable systemd init system in container
ENV INITSYSTEM on
# Expose port
EXPOSE 5353 51826
# Exec homebridge with persistent config
CMD /bin/bash /root/.homebridge/start.sh
All the files are here: https://github.com/chrisrichards/pibell-sub
When deployed on my RasperryPi 3, the mqtt and pibell containers start fine, but Homebridge is stuck in a loop ‘Installing service’. Any ideas how to get homebridge working?
