Hello, I am trying to move on from my Raspberry Pi3 running Hassio to an Odroid XU4 with a similar setup.
I have struggled to compile Hassio on Odroid XU4 on BalenaOS so have decided to try and deploy each component part myself.
So far, I have successfully installed BalenaOS Dev on my Odroid board and accessing it via the Cloud interface.
Using the Cloud interface command line, I have done “balena pull” for a HomeAssistant docker and a NodeRed docker. Both ‘compiled’ successfully and can be launched individually using “balena run”.
Where I am struggling is with the ‘next step’ i.e. putting everything together - this is what I am trying to achieve:
- have a file where I can control runtime options, device attachment, other ‘containers’ (e.g. I want to add an mqtt server" etc etc
 - have a file I can do version updates etc… (i.e. update the file, run “docker build” or something, to update versions)
I have come to “docker-compose.yml”, which might do what I need - where I am struggling is: what do I do with that?
I have tried creating a folder on the HostOS called “hassioxu4”, put the file in there and run “Docker build hassioxu4” but this fails as it complains about the lack of a Dockerfile…
So I am a bit stuck… any help would be appreciated!
Question 2: If I were to stay in my single container by single container environment - how do I control docker containers runtime?
Here is the “docker-compose.yml” file (nota: spaces are not respected below but they are correct in the file) :
version: ‘1’
services:
homeassistant:
container_name: homeassistant
restart: unless-stopped
image: homeassistant/odroid-xu-homeassistant
depends_on:
devices:
- /dev/ttyACM0:/dev/ttyACM0
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
volumes:
- hass-config:/config
- /etc/localtime:/etc/localtime:ro
- /var
network_mode: host
privileged: true
nodered:
container_name: node-red
image: nodered/node-red-docker
depends_on:
- “homeassistant”
volumes:
- nodered-data:/data
ports:
- “1880:1880”
