Hi there, the first thing to try would be to see (assuming you are using the default hostname balenaminecraftserver) if this is resolvable from your client. You can try pinging it to see if it responds. Ideally you should try to do this with both devices on the same network segment (i.e. same Wi-Fi band or Ethernet VLAN).
PING balenaminecraftserver.lan (192.168.1.157): 56 data bytes
64 bytes from 192.168.1.157: icmp_seq=0 ttl=64 time=13.458 ms
64 bytes from 192.168.1.157: icmp_seq=1 ttl=64 time=16.714 ms
64 bytes from 192.168.1.157: icmp_seq=2 ttl=64 time=1.088 ms
64 bytes from 192.168.1.157: icmp_seq=3 ttl=64 time=122.251 ms
Can you try to connect via the IP address directly with the MC client? Do you get the same error message? Is there any output in the server/dashboard logs?
You can also try installing a telnet client on the mac and then run:
telnet 192.168.1.157 <port>
where <port> is either 25565, 25575 or 22 (try all of them to see if you get a socket connection) to see if the server is actually reachable over TCP.
If you can’t get to port 25565 and 25575, that means something is blocking communication between your mac and MV servers. You can test this by opening a web terminal connection to the host container on the device and running curl 192.168.1.157: 25565 as well as curl 192.168.1.157: 25575`. You should get a response if the MC container is running. If so, then you will need to check the network path from your mac to the MC server to see what is blocking these higher numbered ports…
Hi are you able to log into balenaCloud and see the device online and see that all the services are running? If so can you try what Anton suggested above and open a web terminal to the host container on the device and running the curl commands to ensure the mc-server container is functioning correctly? We should probably rule out that everything is functioning correctly first before trying to debug any network issues. Also, can you confirm the model of Pi you are using, as I note that the instructions say the 1GB variant will not work.
Hi Gareth thanks for the reply.
Its a 4GB Pi 4 so should be good.
I am not super familiar with the Balena cloud environment but the only error I can see is this.
21.04.20 22:19:34 (+0100) mc-server Error: Invalid or corrupt jarfile paper.jar
Just tried this too using Terminal MC server
root@balenaminecraftserver:/# curl 192.168.1.157: 22
curl: (7) Failed to connect to 192.168.1.157 port 80: Connection refused
But I can see through my mac network utility that its connected but only port 22 and port 2222 are open.
