I am facing a problem for a project which I am working on. When booting balena OS on my raspberri pi 4 the logo is showing full screen. After booting chromium starts in kiosk mode but only the left part of the screen is visible. The right part shows black.
I don’t know what is causing the problem but maybe you guys could help me out.
Here are some pictures of the screen and some config settings which I’ve tried.
No but when I boot balena os, I see the logo which is full screen and using all the screen. So I think it has to be something that needs to be configured for chromium or in config.txt.
ah I missed the part about the boot splash working fine. how are you deploying chromium kiosk? we are building https://github.com/balenablocks/browser maybe you can check with that or at least see what kind of options it sets/wants
You may also want to check the gpu memory settings in your Device Configuration menu. The Pi shouldn’t have a problem driving a monitor your size, but you may need to commit more memory (try 128, for example).
