Hi. I am running this host image:
cat resin-boot/os-release
ID="balena-os"
NAME="balenaOS"
VERSION="2.82.11+rev8"
VERSION_ID="2.82.11+rev8"
PRETTY_NAME="balenaOS 2.82.11+rev8"
MACHINE="jetson-xavier-nx-devkit"
VARIANT="Development"
VARIANT_ID=dev
META_BALENA_VERSION="2.82.11"
I tried to build my image locally but it fails with the following error:
[Build] main gpu id :0 not exist !
[Build] main Loading pre-trained weights...
[Build] main Weights loading complete!
[Build] main ERROR: CUDA initialization failure with error 100. Please check your CUDA installation: http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
[Build] main Segmentation fault (core dumped)
It seems like the gpu is not visible.
Running command balena run -it --rm --gpus all balenalib/jetson-xavier-nx-devkit-ubuntu:bionic-build bash on the host, I get the following error:
balena: Error response from daemon: could not select device driver "" with capabilities: [[gpu]].
I might be missing something but the gpus should be visible, no? How can I trouble shoot this?
