I upgraded the balena base image from genericx86-64-ext-debian-node:12-buster to genericx86-64-ext-debian-node:latest-bullseye and the systemd config stopped working.
The current configuration is the one here: base-images/examples/INITSYSTEM/systemd/systemd.v230 at master · balena-io-library/base-images · GitHub
I am running some services of my application, which are not starting
When I run systemctl status default.target I get the message: default.target is masked.
I am getting the following error in the console
