Hi guys,
I’m trying to get systemd running according to the Installing your own Initsystem article. I tried the examples in the article and also used this one here GitHub - balena-io-examples/balenalib-systemd-example: Example project using systemd with balenalib images. However, ultimately I always get stuck with
mount: /tmp/tmpmount/console: special device /dev/console does not exist. I can’t seem to find a solution and was hoping you guys can help me out.
Dockerfile
balenalib-systemd-example/Dockerfile.template at master · balena-io-examples/balenalib-systemd-example · GitHub same as this except i’m using
Basically the same as the examples, except I’m using the raspberrypi3-debian base image.
entry.sh and balena.service are the same from the example above.
Note; I can’t post my Dockerfile etc as apparently new Users are only allowed to post 5 links and it recognises lines like entry.sh as a link - haha
Thanks in advance
