Generated ResinOS Image Download Fails
I’ve successfully created a Raspberry Pi Zero application, but when I configure and try to download its ResinOS image, I’m shown the message: “Cannot read property ‘1’ of null”.
I’ve tried different versions and file types, all produce the same result.
Is there a current issue with the service?
Larrry
Hi, we have ongoing maintenance at the moment (see more info at http://status.resin.io/ ), but this shouldn’t affect the image download. I’ve confirmed it too, and investigating. Sorry for the inconvenience.
Thanks for looking into this!
Looks like our developers are already working on this, will keep you posted!
Hey @brightcontrast, it should be back to normal. Seemed to have been an out of space issue with the image maker that prepares those downloads. Now looking at the root cause to make sure it does not happen again.
Thanks for the heads up. I’ll resume setting up my Pi.
