Versions
FreeBSD:
TwinCAT/BSD(FreeBSD): 12.2-RELEASE-p12 FreeBSD 12.2-RELEASE-p12
vm-bhyve: Bhyve virtual machine management v1.4.2 (rev. 104002)
Balena:
Seleced device type: Intel NUC
Selected version: v2.105.16
Selected OS type: balenaOS
Description
I would like to run my BalenaOS “device” within a virtual machine(bhyve) on my existing PLC.
For the configuration of bhyve I use vm-bhyve.
At startup I have to configure grub to get it started.
I did following configuration:
grub> ls
(cd0) (cd0,msdos6) (cd0,msdos5) (cd0,msdos3) (cd0,msdos2) (cd0,msdos1) (hd0) (h
ost)
grub> ls (cd0,msdos1)/
efi/ balena-image-flasher balenaos.fingerprint config.json device-type.json gru
b/ grub.cfg_internal grub.cfg_internal_luks image-version-info splash/ system-c
onnections/ System Volume Information/
grub> set prefix=(cd0,1)/grub
grub> set root=(hd0,1)
grub> insmod linux
grub> insmod normal
grub> normal
Output:
Linux version 5.14.21-yocto-standard (oe-user@oe-host) (x86_64-poky-linux-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.37.20210721) #1 SMP PREEMPT Mon Nov 29 01:17:48 UTC 2021
Command line: console=ttyS0 BOOT_IMAGE=/boot/bzImage root=LABEL=flash-rootA flasher rootwait
x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
signal: max sigframe size: 1776
BIOS-provided physical RAM map:
BIOS-e820: [mem 0x0000000000000000-0x000000000009fffe] usable
BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
NX (Execute Disable) protection: active
SMBIOS 2.6 present.
DMI: BHYVE, BIOS 1.00 03/14/2014
tsc: Fast TSC calibration using PIT
tsc: Detected 3343.546 MHz processor
last_pfn = 0x20000 max_arch_pfn = 0x400000000
Disabled
x86/PAT: MTRRs disabled, skipping PAT initialization too.
CPU MTRRs all blank - virtualized system.
x86/PAT: Configuration [0-7]: WB WT UC- UC WB WT UC- UC
found SMP MP-table at [mem 0x000f0000-0x000f000f]
Using GB pages for direct mapping
ACPI: Early table checksum verification disabled
ACPI: RSDP 0x00000000000F2400 000024 (v02 BHYVE )
ACPI: XSDT 0x00000000000F2480 000044 (v01 BHYVE BVXSDT 00000001 INTL 20200430)
ACPI: APIC 0x00000000000F2500 00005A (v01 BHYVE BVMADT 00000001 INTL 20200430)
ACPI: FACP 0x00000000000F25D2 00010C (v05 BHYVE BVFACP 00000001 INTL 20200430)
ACPI: DSDT 0x00000000000F2852 00097B (v02 BHYVE BVDSDT 00000001 INTL 20200430)
ACPI: FACS 0x00000000000F2792 000040
ACPI: HPET 0x00000000000F2712 000038 (v01 BHYVE BVHPET 00000001 INTL 20200430)
ACPI: MCFG 0x00000000000F2752 00003C (v01 BHYVE BVMCFG 00000001 INTL 20200430)
ACPI: Reserving APIC table memory at [mem 0xf2500-0xf2559]
ACPI: Reserving FACP table memory at [mem 0xf25d2-0xf26dd]
ACPI: Reserving DSDT table memory at [mem 0xf2852-0xf31cc]
ACPI: Reserving FACS table memory at [mem 0xf2792-0xf27d1]
ACPI: Reserving HPET table memory at [mem 0xf2712-0xf2749]
ACPI: Reserving MCFG table memory at [mem 0xf2752-0xf278d]
Setting APIC routing to physical flat.
Zone ranges:
DMA [mem 0x0000000000001000-0x0000000000ffffff]
DMA32 [mem 0x0000000001000000-0x000000001fffffff]
Normal empty
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x0000000000001000-0x000000000009efff]
node 0: [mem 0x0000000000100000-0x000000001fffffff]
Initmem setup node 0 [mem 0x0000000000001000-0x000000001fffffff]
On node 0, zone DMA: 1 pages in unavailable ranges
On node 0, zone DMA: 97 pages in unavailable ranges
ACPI: PM-Timer IO Port: 0x408
ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-31
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x80860701 base: 0xfed00000
smpboot: Allowing 1 CPUs, 0 hotplug CPUs
[mem 0x20000000-0xffffffff] available for PCI devices
Booting paravirtualized kernel on bare hardware
clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:1 nr_node_ids:1
percpu: Embedded 57 pages/cpu s195864 r8192 d29416 u2097152
Built 1 zonelists, mobility grouping on. Total pages: 128768
Kernel command line: console=ttyS0 BOOT_IMAGE=/boot/bzImage root=LABEL=flash-rootA flasher rootwait
Unknown command line parameters: flasher BOOT_IMAGE=/boot/bzImage
Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 472740K/523896K available (14347K kernel code, 2200K rwdata, 3696K rodata, 14316K init, 1800K bss, 50896K reserved, 0K cma-reserved)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
ftrace: allocating 49516 entries in 194 pages
ftrace: allocated 194 pages with 3 groups
rcu: Preemptible hierarchical RCU implementation.
rcu: RCU event tracing is enabled.
rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=1.
Trampoline variant of Tasks RCU enabled.
Rude variant of Tasks RCU enabled.
Tracing variant of Tasks RCU enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
NR_IRQS: 4352, nr_irqs: 256, preallocated irqs: 16
kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
random: get_random_bytes called from start_kernel+0x4cc/0x698 with crng_init=0
Console: colour EGA 80x25
printk: console [ttyS0] enabled
ACPI: Core revision 20210604
clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 113919999973 ns
APIC: Switch to symmetric I/O mode setup
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3031fc983fd, max_idle_ns: 440795203904 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6687.09 BogoMIPS (lpj=3343546)
pid_max: default: 32768 minimum: 301
LSM: Security Framework initializing
landlock: Up and running.
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Spectre V2 : Mitigation: Full AMD retpoline
Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Freeing SMP alternatives memory: 20K
smpboot: CPU0: AMD Ryzen Embedded V1807B with Radeon Vega Gfx (family: 0x17, model: 0x11, stepping: 0x0)
Performance Events: PMU not available due to virtualization, using software events only.
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
smp: Brought up 1 node, 1 CPU
smpboot: Max logical packages: 1
smpboot: Total of 1 processors activated (6687.09 BogoMIPS)
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
futex hash table entries: 256 (order: 2, 16384 bytes, linear)
pinctrl core: initialized pinctrl subsystem
NET: Registered PF_NETLINK/PF_ROUTE protocol family
thermal_sys: Registered thermal governor 'step_wise'
thermal_sys: Registered thermal governor 'user_space'
cpuidle: using governor menu
ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
ACPI: bus type PCI registered
PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
PCI: not using MMCONFIG
PCI: Using configuration type 1 for base access
PCI: Using configuration type 1 for extended access
Kprobes globally optimized
raid6: avx2x4 gen() 21363 MB/s
raid6: avx2x4 xor() 8075 MB/s
raid6: avx2x2 gen() 23509 MB/s
raid6: avx2x2 xor() 14568 MB/s
raid6: avx2x1 gen() 19352 MB/s
raid6: avx2x1 xor() 12230 MB/s
raid6: sse2x4 gen() 13230 MB/s
raid6: sse2x4 xor() 7312 MB/s
raid6: sse2x2 gen() 13533 MB/s
raid6: sse2x2 xor() 8719 MB/s
raid6: sse2x1 gen() 11642 MB/s
raid6: sse2x1 xor() 6220 MB/s
raid6: using algorithm avx2x2 gen() 23509 MB/s
raid6: .... xor() 14568 MB/s, rmw enabled
raid6: using avx2x2 recovery algorithm
ACPI: Added _OSI(Module Device)
ACPI: Added _OSI(Processor Device)
ACPI: Added _OSI(3.0 _SCP Extensions)
ACPI: Added _OSI(Processor Aggregator Device)
ACPI: Added _OSI(Linux-Dell-Video)
ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
ACPI: 1 ACPI AML tables successfully acquired and loaded
ACPI: Interpreter enabled
ACPI: PM: (supports S0 S5)
ACPI: Using IOAPIC for interrupt routing
PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00])
acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
pci_bus 0000:00: root bus resource [io 0x0d00-0x1fff window]
pci_bus 0000:00: root bus resource [io 0x2000-0x203f window]
pci_bus 0000:00: root bus resource [mem 0xc0000000-0xc01fffff window]
pci_bus 0000:00: root bus resource [mem 0x800000000-0x8000fffff window]
pci_bus 0000:00: root bus resource [bus 00]
pci 0000:00:00.0: [1275:1275] type 00 class 0x060000
pci 0000:00:03.0: [8086:2821] type 00 class 0x010601
pci 0000:00:03.0: reg 0x24: [mem 0xc0002000-0xc00023ff]
pci 0000:00:04.0: [8086:2821] type 00 class 0x010601
pci 0000:00:04.0: reg 0x24: [mem 0xc0002400-0xc00027ff]
pci 0000:00:05.0: [1af4:1000] type 00 class 0x020000
pci 0000:00:05.0: reg 0x10: [io 0x2000-0x201f]
pci 0000:00:05.0: reg 0x14: [mem 0xc0000000-0xc0001fff]
pci 0000:00:1f.0: [8086:7000] type 00 class 0x060100
ACPI: PCI: Interrupt link LNKA configured for IRQ 5
ACPI: PCI: Interrupt link LNKB configured for IRQ 6
ACPI: PCI: Interrupt link LNKC configured for IRQ 7
ACPI: PCI: Interrupt link LNKD configured for IRQ 0
ACPI: PCI: Interrupt link LNKD disabled
ACPI: PCI: Interrupt link LNKE configured for IRQ 0
ACPI: PCI: Interrupt link LNKE disabled
ACPI: PCI: Interrupt link LNKF configured for IRQ 0
ACPI: PCI: Interrupt link LNKF disabled
ACPI: PCI: Interrupt link LNKG configured for IRQ 0
ACPI: PCI: Interrupt link LNKG disabled
ACPI: PCI: Interrupt link LNKH configured for IRQ 0
ACPI: PCI: Interrupt link LNKH disabled
iommu: Default domain type: Translated
vgaarb: loaded
SCSI subsystem initialized
ACPI: bus type USB registered
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered PF_BLUETOOTH protocol family
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
PCI: Using ACPI for IRQ routing
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
hpet0: 8 comparators, 32-bit 16.777216 MHz counter
clocksource: Switched to clocksource tsc-early
pnp: PnP ACPI init
system 00:02: [io 0x0220-0x0223] has been reserved
system 00:02: [io 0x0224-0x0227] has been reserved
system 00:02: [io 0x04d0-0x04d1] has been reserved
system 00:02: [io 0x0400-0x0407] has been reserved
system 00:02: [mem 0xe0000000-0xefffffff] has been reserved
pnp: PnP ACPI: found 6 devices
clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
NET: Registered PF_INET protocol family
IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
NET: Registered PF_UNIX/PF_LOCAL protocol family
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
pci_bus 0000:00: resource 5 [io 0x0d00-0x1fff window]
pci_bus 0000:00: resource 6 [io 0x2000-0x203f window]
pci_bus 0000:00: resource 7 [mem 0xc0000000-0xc01fffff window]
pci_bus 0000:00: resource 8 [mem 0x800000000-0x8000fffff window]
pci 0000:00:1f.0: Activating ISA DMA hang workarounds
PCI: CLS 0 bytes, default 64
Initialise system trusted keyrings
workingset: timestamp_bits=46 max_order=17 bucket_order=0
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
Key type cifs.idmap registered
aufs 5.x-rcN-20210308
xor: automatically using best checksumming function avx
Key type asymmetric registered
Asymmetric key parser 'x509' registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
io scheduler mq-deadline registered
io scheduler kyber registered
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
ACPI: button: Power Button [PWRF]
virtio-pci 0000:00:05.0: virtio_pci: leaving for legacy driver
Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
00:04: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
Linux agpgart interface v0.103
brd: module loaded
loop: module loaded
zram: Added device: zram0
hv_vmbus: registering driver hv_storvsc
ahci 0000:00:03.0: SSS flag set, parallel bus scan disabled
ahci 0000:00:03.0: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x1 impl SATA mode
ahci 0000:00:03.0: flags: 64bit ncq sntf ilck stag pm led clo pio slum part sxs apst
scsi host0: ahci
scsi host1: ahci
scsi host2: ahci
scsi host3: ahci
scsi host4: ahci
scsi host5: ahci
ata1: SATA max UDMA/133 abar m1024@0xc0002000 port 0xc0002100 irq 32
ata2: DUMMY
ata3: DUMMY
ata4: DUMMY
ata5: DUMMY
ata6: DUMMY
ahci 0000:00:04.0: SSS flag set, parallel bus scan disabled
ahci 0000:00:04.0: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x1 impl SATA mode
ahci 0000:00:04.0: flags: 64bit ncq sntf ilck stag pm led clo pio slum part sxs apst
scsi host6: ahci
scsi host7: ahci
scsi host8: ahci
scsi host9: ahci
scsi host10: ahci
scsi host11: ahci
ata7: SATA max UDMA/133 abar m1024@0xc0002400 port 0xc0002500 irq 33
ata8: DUMMY
ata9: DUMMY
ata10: DUMMY
ata11: DUMMY
ata12: DUMMY
tun: Universal TUN/TAP device driver, 1.6
e100: Intel(R) PRO/100 Network Driver
e100: Copyright(c) 1999-2006 Intel Corporation
e1000: Intel(R) PRO/1000 Network Driver
e1000: Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-platform: EHCI generic platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
uhci_hcd: USB Universal Host Controller Interface driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
i8042: Warning: Keylock active
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
hv_vmbus: registering driver hyperv_keyboard
mousedev: PS/2 mouse device common for all mice
input: AT Raw Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
rtc_cmos 00:05: registered as rtc0
rtc_cmos 00:05: setting system clock to 2022-10-26T17:04:57 UTC (1666803897)
rtc_cmos 00:05: alarms up to one day, y3k, 114 bytes nvram
fail to initialize ptp_kvm
device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hid: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
u32 classifier
input device check on
Actions configured
IPVS: Registered protocols ()
IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
IPVS: ipvs loaded.
NET: Registered PF_INET6 protocol family
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered PF_PACKET protocol family
Bridge firewalling registered
Key type dns_resolver registered
NET: Registered PF_VSOCK protocol family
IPI shorthand broadcast: enabled
sched_clock: Marking stable (718483445, 50119207)->(770020676, -1418024)
registered taskstats version 1
Loading compiled-in X.509 certificates
Key type ._fscrypt registered
Key type .fscrypt registered
Key type fscrypt-provisioning registered
Btrfs loaded, crc32c=crc32c-generic, zoned=no
Key type encrypted registered
printk: console [netcon0] enabled
netconsole: network logging started
ALSA device list:
No soundcards found.
ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata1.00: ATAPI: BHYVE SATA DVD ROM, 001, max MWDMA2
ata1.00: configured for PIO4
ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata7.00: ATA-9: BHYVE SATA DISK, 001, max MWDMA2
ata7.00: 20971520 sectors, multi 0: LBA48 NCQ (depth 32)
ata7.00: configured for PIO4
scsi 0:0:0:0: CD-ROM BHYVE BHYVE DVD-ROM 001 PQ: 0 ANSI: 5
sr 0:0:0:0: [sr0] scsi3-mmc drive: 0x/0x xa/form2 caddy
cdrom: Uniform CD-ROM driver Revision: 3.20
scsi 6:0:0:0: Direct-Access ATA BHYVE SATA DISK 001 PQ: 0 ANSI: 5
sd 6:0:0:0: [sda] 20971520 512-byte logical blocks: (10.7 GB/10.0 GiB)
sd 6:0:0:0: [sda] 131072-byte physical blocks
sd 6:0:0:0: [sda] Write Protect is off
sd 6:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 6:0:0:0: [sda] Attached SCSI disk
Freeing unused kernel image (initmem) memory: 14316K
Write protecting the kernel read-only data: 20480k
Freeing unused kernel image (text/rodata gap) memory: 2036K
Freeing unused kernel image (rodata/data gap) memory: 400K
Run /init as init process
Starting version 249
virtio_net virtio0 enp0s5: renamed from eth0
random: fast init done
zram0: detected capacity change from 0 to 489776
input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input3
tsc: Refined TSC clocksource calibration: 3341.303 MHz
clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3029b5af021, max_idle_ns: 440795308761 ns
clocksource: timekeeping watchdog on CPU0: Marking clocksource 'tsc' as unstable because the skew is too large:
clocksource: 'hpet' wd_nsec: 497499644 wd_now: 203914c wd_last: 1843529 mask: ffffffff
clocksource: 'tsc' cs_nsec: 497858097 cs_now: a6e058e8d61 cs_last: a6da267a35d mask: ffffffffffffffff
clocksource: 'tsc' is current clocksource.
tsc: Marking TSC unstable due to clocksource watchdog
TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
sched_clock: Marking unstable (2051579037, 50119215)<-(2103117408, -1418024)
clocksource: Not enough CPUs to check clocksource 'tsc'.
clocksource: Switched to clocksource hpet
root '/dev/disk/by-label/flash-rootA' doesn't exist or does not contain a /dev.
So the system is booting, but there is something wrong with my grub configuration?
Do you have a idea what I have to do to get it running?
Thank you!
What I would expect
Working BalenaOS as bhyve guest.
