Flash failed when trying to flash LinuxMint
I’m trying to get Linux mint onto a flash stick. I uploaded the file and selected the usb. I then said continue. I’ve tried about 4 times and its still not working. Any ideas on what I should do. Any help is fine. I’m a little stuck. Its my first time.
Here’s the image for reference
Hello @puurlord,
Which version of Etcher are you using? If you haven’t done so, please upgrade to the latest version. Have you tried a different flash stick? If so, do you still get an error?
On Windows you can use CTRL - SHIFT - I to access the developer console and see any detailed error messages in the log within the console tab. If there are any errors here feel free to post them so we can investigate further.
Thank you very much for replying. I will try a different usb stick. Regarding the update, Its recently installed and is on the latest version. I will also try the ctl - shift command you suggested. Thank you again. I’ll get back if I run into any further issues
I am having the same problem. Validation completes and process finishes, but this I get flash failed screen. Pasting text from console below…
gui.js:46 Thu Sep 01 2022 20:06:13 GMT-0400 (Eastern Daylight Time) Restart ({“sample”:0.1,“applicationSessionUuid”:“2d0c526a-1e8d-4ede-abf3-8f3d6613c4dd”,“flashingWorkflowUuid”:“46828c32-92b9-42a5-972c-f79068a61cbb”})
gui.js:46 Thu Sep 01 2022 20:06:22 GMT-0400 (Eastern Daylight Time) Flash ({“image”:{“size”:1543503872,“name”:“lmde-2-201701-mate-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:1537544192,“size”:2424832,“type”:239,“index”:1}],“extension”:“iso”,“path”:“C:\Linux Mint MATE\lmde-2-201701-mate-64bit.iso”},“drives”:[{“size”:30765219840,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:" USB SanDisk 3.2Gen1 USB Device",“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“6042400f-de7c-4ddb-8963-9392243e2c3e”,“status”:“started”,“flashInstanceUuid”:“6042400f-de7c-4ddb-8963-9392243e2c3e”,“sample”:0.1,“applicationSessionUuid”:“2d0c526a-1e8d-4ede-abf3-8f3d6613c4dd”,“flashingWorkflowUuid”:“d14c9557-0e41-475a-94b5-d3a51960cde0”})
gui.js:46 Elevating command: C:\Users\KunzAdmin\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\KunzAdmin\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:46 Thu Sep 01 2022 20:06:22 GMT-0400 (Eastern Daylight Time) SafeWebview loaded ({“event”:{“id”:95,“url”:“Etcher Featured Project 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:[“*”],“age”:[“453”],“alt-svc”:[“h3=":443"; ma=86400, h3-29=":443"; ma=86400”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“7441ffddb8165a3f-IAD”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Fri, 02 Sep 2022 00:06:23 GMT”],“expires”:[“Thu, 01 Sep 2022 15:00:01 GMT”],“last-modified”:[“Thu, 01 Sep 2022 14:41:05 GMT”],“nel”:[“{"success_fraction":0,"report_to":"cf-nel","max_age":604800}”],“report-to”:[“{"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=KZOFg8cVO3fb0sZqDOv6CtB%2BIRwip6aynHq1ZkRpVsF94wEl2A3rmivWLiV7U7o3gJA1xgXEZCc%2Betmx6ZvrwLJnTGTNEtjVEWv92%2B5dPauaTx37CnDCgfQZt7BnPOD22Imd"}],"group":"cf-nel","max_age":604800}”],“server”:[“cloudflare”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“641bb03c6d22387f90e1333d8a946312ee9dd1f7”],“x-github-request-id”:[“22DC:42EF:42509B:709AFF:6310C699”],“x-origin-cache”:[“HIT”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-iad-kiad7000020-IAD”],“x-timer”:[“S1662077184.648023,VS0,VE1”]},“referrer”:“”,“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“2d0c526a-1e8d-4ede-abf3-8f3d6613c4dd”,“flashingWorkflowUuid”:“d14c9557-0e41-475a-94b5-d3a51960cde0”})
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:46 Successfully connected to IPC server: etcher-server-11004, socket root C:\Users\KUNZAD~1\AppData\Local\Temp
gui.js:46 Image: C:\Linux Mint MATE\lmde-2-201701-mate-64bit.iso
gui.js:46 Devices: \.\PhysicalDrive1
gui.js:46 Auto blockmapping: true
gui.js:46 Decompress first: true
gui.js:35 Flashing 1 device, 0% at 4.00 MB/s (total 4.00 MB/s) eta in 387s with 0 failed devices
gui.js:35 Flashing 1 device, 1% at 4.10 MB/s (total 4.10 MB/s) eta in 375s with 0 failed devices
gui.js:35 Flashing 1 device, 2% at 7.30 MB/s (total 7.30 MB/s) eta in 206s with 0 failed devices
gui.js:35 Flashing 1 device, 3% at 19.90 MB/s (total 19.90 MB/s) eta in 75s with 0 failed devices
gui.js:35 Flashing 1 device, 4% at 19.20 MB/s (total 19.20 MB/s) eta in 76s with 0 failed devices
gui.js:35 Flashing 1 device, 6% at 18.60 MB/s (total 18.60 MB/s) eta in 78s with 0 failed devices
gui.js:35 Flashing 1 device, 7% at 19.20 MB/s (total 19.20 MB/s) eta in 74s with 0 failed devices
gui.js:35 Flashing 1 device, 9% at 19.80 MB/s (total 19.80 MB/s) eta in 71s with 0 failed devices
gui.js:35 Flashing 1 device, 9% at 19.80 MB/s (total 19.80 MB/s) eta in 70s with 0 failed devices
gui.js:35 Flashing 1 device, 11% at 20.10 MB/s (total 20.10 MB/s) eta in 68s with 0 failed devices
gui.js:35 Flashing 1 device, 12% at 19.20 MB/s (total 19.20 MB/s) eta in 70s with 0 failed devices
gui.js:35 Flashing 1 device, 13% at 18.50 MB/s (total 18.50 MB/s) eta in 72s with 0 failed devices
gui.js:35 Flashing 1 device, 15% at 19.60 MB/s (total 19.60 MB/s) eta in 67s with 0 failed devices
gui.js:35 Flashing 1 device, 16% at 19.80 MB/s (total 19.80 MB/s) eta in 65s with 0 failed devices
gui.js:35 Flashing 1 device, 18% at 19.40 MB/s (total 19.40 MB/s) eta in 65s with 0 failed devices
gui.js:35 Flashing 1 device, 18% at 19.20 MB/s (total 19.20 MB/s) eta in 65s with 0 failed devices
gui.js:35 Flashing 1 device, 20% at 20.00 MB/s (total 20.00 MB/s) eta in 61s with 0 failed devices
gui.js:35 Flashing 1 device, 21% at 19.60 MB/s (total 19.60 MB/s) eta in 62s with 0 failed devices
gui.js:35 Flashing 1 device, 23% at 19.70 MB/s (total 19.70 MB/s) eta in 60s with 0 failed devices
gui.js:35 Flashing 1 device, 24% at 18.60 MB/s (total 18.60 MB/s) eta in 63s with 0 failed devices
gui.js:35 Flashing 1 device, 25% at 19.20 MB/s (total 19.20 MB/s) eta in 60s with 0 failed devices
gui.js:35 Flashing 1 device, 26% at 18.60 MB/s (total 18.60 MB/s) eta in 61s with 0 failed devices
gui.js:35 Flashing 1 device, 27% at 19.60 MB/s (total 19.60 MB/s) eta in 57s with 0 failed devices
gui.js:35 Flashing 1 device, 29% at 19.70 MB/s (total 19.70 MB/s) eta in 55s with 0 failed devices
gui.js:35 Flashing 1 device, 30% at 19.20 MB/s (total 19.20 MB/s) eta in 56s with 0 failed devices
gui.js:35 Flashing 1 device, 31% at 19.20 MB/s (total 19.20 MB/s) eta in 55s with 0 failed devices
gui.js:35 Flashing 1 device, 32% at 19.40 MB/s (total 19.40 MB/s) eta in 53s with 0 failed devices
gui.js:35 Flashing 1 device, 34% at 19.20 MB/s (total 19.20 MB/s) eta in 53s with 0 failed devices
gui.js:35 Flashing 1 device, 35% at 18.90 MB/s (total 18.90 MB/s) eta in 53s with 0 failed devices
gui.js:35 Flashing 1 device, 37% at 18.70 MB/s (total 18.70 MB/s) eta in 52s with 0 failed devices
gui.js:35 Flashing 1 device, 38% at 19.60 MB/s (total 19.60 MB/s) eta in 49s with 0 failed devices
gui.js:35 Flashing 1 device, 39% at 18.40 MB/s (total 18.40 MB/s) eta in 51s with 0 failed devices
gui.js:35 Flashing 1 device, 40% at 19.60 MB/s (total 19.60 MB/s) eta in 47s with 0 failed devices
gui.js:35 Flashing 1 device, 41% at 20.10 MB/s (total 20.10 MB/s) eta in 45s with 0 failed devices
gui.js:35 Flashing 1 device, 43% at 18.90 MB/s (total 18.90 MB/s) eta in 46s with 0 failed devices
gui.js:35 Flashing 1 device, 44% at 18.40 MB/s (total 18.40 MB/s) eta in 47s with 0 failed devices
gui.js:35 Flashing 1 device, 45% at 19.60 MB/s (total 19.60 MB/s) eta in 43s with 0 failed devices
gui.js:35 Flashing 1 device, 47% at 20.10 MB/s (total 20.10 MB/s) eta in 41s with 0 failed devices
gui.js:35 Flashing 1 device, 48% at 20.10 MB/s (total 20.10 MB/s) eta in 39s with 0 failed devices
gui.js:35 Flashing 1 device, 49% at 19.40 MB/s (total 19.40 MB/s) eta in 40s with 0 failed devices
gui.js:35 Flashing 1 device, 50% at 19.60 MB/s (total 19.60 MB/s) eta in 39s with 0 failed devices
gui.js:35 Flashing 1 device, 52% at 19.10 MB/s (total 19.10 MB/s) eta in 39s with 0 failed devices
gui.js:35 Flashing 1 device, 53% at 19.10 MB/s (total 19.10 MB/s) eta in 38s with 0 failed devices
gui.js:35 Flashing 1 device, 54% at 19.70 MB/s (total 19.70 MB/s) eta in 35s with 0 failed devices
gui.js:35 Flashing 1 device, 56% at 19.70 MB/s (total 19.70 MB/s) eta in 34s with 0 failed devices
gui.js:35 Flashing 1 device, 57% at 19.10 MB/s (total 19.10 MB/s) eta in 35s with 0 failed devices
gui.js:35 Flashing 1 device, 58% at 19.60 MB/s (total 19.60 MB/s) eta in 33s with 0 failed devices
gui.js:35 Flashing 1 device, 59% at 19.60 MB/s (total 19.60 MB/s) eta in 32s with 0 failed devices
gui.js:35 Flashing 1 device, 61% at 19.00 MB/s (total 19.00 MB/s) eta in 32s with 0 failed devices
gui.js:35 Flashing 1 device, 62% at 19.10 MB/s (total 19.10 MB/s) eta in 31s with 0 failed devices
gui.js:35 Flashing 1 device, 63% at 19.60 MB/s (total 19.60 MB/s) eta in 29s with 0 failed devices
gui.js:35 Flashing 1 device, 64% at 19.60 MB/s (total 19.60 MB/s) eta in 28s with 0 failed devices
gui.js:35 Flashing 1 device, 66% at 18.90 MB/s (total 18.90 MB/s) eta in 28s with 0 failed devices
gui.js:35 Flashing 1 device, 67% at 19.40 MB/s (total 19.40 MB/s) eta in 26s with 0 failed devices
gui.js:35 Flashing 1 device, 69% at 19.20 MB/s (total 19.20 MB/s) eta in 25s with 0 failed devices
gui.js:35 Flashing 1 device, 69% at 18.80 MB/s (total 18.80 MB/s) eta in 25s with 0 failed devices
gui.js:35 Flashing 1 device, 71% at 19.60 MB/s (total 19.60 MB/s) eta in 23s with 0 failed devices
gui.js:35 Flashing 1 device, 72% at 20.00 MB/s (total 20.00 MB/s) eta in 21s with 0 failed devices
gui.js:35 Flashing 1 device, 73% at 18.90 MB/s (total 18.90 MB/s) eta in 21s with 0 failed devices
gui.js:35 Flashing 1 device, 74% at 17.00 MB/s (total 17.00 MB/s) eta in 23s with 0 failed devices
gui.js:35 Flashing 1 device, 75% at 14.00 MB/s (total 14.00 MB/s) eta in 27s with 0 failed devices
gui.js:35 Flashing 1 device, 76% at 13.90 MB/s (total 13.90 MB/s) eta in 26s with 0 failed devices
gui.js:35 Flashing 1 device, 77% at 13.80 MB/s (total 13.80 MB/s) eta in 25s with 0 failed devices
gui.js:35 Flashing 1 device, 78% at 13.80 MB/s (total 13.80 MB/s) eta in 24s with 0 failed devices
gui.js:35 Flashing 1 device, 79% at 15.50 MB/s (total 15.50 MB/s) eta in 20s with 0 failed devices
gui.js:35 Flashing 1 device, 80% at 13.90 MB/s (total 13.90 MB/s) eta in 22s with 0 failed devices
gui.js:35 Flashing 1 device, 81% at 13.50 MB/s (total 13.50 MB/s) eta in 21s with 0 failed devices
gui.js:35 Flashing 1 device, 82% at 14.90 MB/s (total 14.90 MB/s) eta in 18s with 0 failed devices
gui.js:35 Flashing 1 device, 83% at 14.30 MB/s (total 14.30 MB/s) eta in 18s with 0 failed devices
gui.js:35 Flashing 1 device, 84% at 13.80 MB/s (total 13.80 MB/s) eta in 18s with 0 failed devices
gui.js:35 Flashing 1 device, 84% at 13.70 MB/s (total 13.70 MB/s) eta in 17s with 0 failed devices
gui.js:35 Flashing 1 device, 86% at 14.40 MB/s (total 14.40 MB/s) eta in 15s with 0 failed devices
gui.js:35 Flashing 1 device, 86% at 15.10 MB/s (total 15.10 MB/s) eta in 13s with 0 failed devices
gui.js:35 Flashing 1 device, 88% at 13.90 MB/s (total 13.90 MB/s) eta in 13s with 0 failed devices
gui.js:35 Flashing 1 device, 88% at 14.30 MB/s (total 14.30 MB/s) eta in 12s with 0 failed devices
gui.js:35 Flashing 1 device, 89% at 13.80 MB/s (total 13.80 MB/s) eta in 12s with 0 failed devices
gui.js:35 Flashing 1 device, 90% at 13.40 MB/s (total 13.40 MB/s) eta in 11s with 0 failed devices
gui.js:35 Flashing 1 device, 91% at 15.40 MB/s (total 15.40 MB/s) eta in 8s with 0 failed devices
gui.js:35 Flashing 1 device, 92% at 14.30 MB/s (total 14.30 MB/s) eta in 8s with 0 failed devices
gui.js:35 Flashing 1 device, 93% at 14.00 MB/s (total 14.00 MB/s) eta in 7s with 0 failed devices
gui.js:35 Flashing 1 device, 94% at 15.50 MB/s (total 15.50 MB/s) eta in 5s with 0 failed devices
gui.js:35 Flashing 1 device, 95% at 14.30 MB/s (total 14.30 MB/s) eta in 5s with 0 failed devices
gui.js:35 Flashing 1 device, 96% at 13.40 MB/s (total 13.40 MB/s) eta in 4s with 0 failed devices
gui.js:35 Flashing 1 device, 97% at 13.90 MB/s (total 13.90 MB/s) eta in 3s with 0 failed devices
gui.js:35 Flashing 1 device, 98% at 14.30 MB/s (total 14.30 MB/s) eta in 2s with 0 failed devices
gui.js:35 Flashing 1 device, 99% at 15.30 MB/s (total 15.30 MB/s) eta in 1s with 0 failed devices
gui.js:35 Flashing 1 device, 100% at 13.40 MB/s (total 13.40 MB/s) eta in 0s with 0 failed devices
gui.js:35 Verifying 1 device, 1% at 29.40 MB/s (total 29.40 MB/s) eta in 52s with 0 failed devices
gui.js:35 Verifying 1 device, 2% at 31.10 MB/s (total 31.10 MB/s) eta in 48s with 0 failed devices
gui.js:35 Verifying 1 device, 4% at 33.00 MB/s (total 33.00 MB/s) eta in 45s with 0 failed devices
gui.js:35 Verifying 1 device, 6% at 32.90 MB/s (total 32.90 MB/s) eta in 44s with 0 failed devices
gui.js:35 Verifying 1 device, 9% at 33.00 MB/s (total 33.00 MB/s) eta in 42s with 0 failed devices
gui.js:35 Verifying 1 device, 11% at 33.10 MB/s (total 33.10 MB/s) eta in 41s with 0 failed devices
gui.js:35 Verifying 1 device, 13% at 33.00 MB/s (total 33.00 MB/s) eta in 40s with 0 failed devices
gui.js:35 Verifying 1 device, 15% at 32.90 MB/s (total 32.90 MB/s) eta in 40s with 0 failed devices
gui.js:35 Verifying 1 device, 17% at 33.20 MB/s (total 33.20 MB/s) eta in 38s with 0 failed devices
gui.js:35 Verifying 1 device, 20% at 33.60 MB/s (total 33.60 MB/s) eta in 37s with 0 failed devices
gui.js:35 Verifying 1 device, 22% at 32.90 MB/s (total 32.90 MB/s) eta in 36s with 0 failed devices
gui.js:35 Verifying 1 device, 24% at 32.80 MB/s (total 32.80 MB/s) eta in 36s with 0 failed devices
gui.js:35 Verifying 1 device, 26% at 33.00 MB/s (total 33.00 MB/s) eta in 34s with 0 failed devices
gui.js:35 Verifying 1 device, 28% at 33.10 MB/s (total 33.10 MB/s) eta in 33s with 0 failed devices
gui.js:35 Verifying 1 device, 30% at 33.80 MB/s (total 33.80 MB/s) eta in 32s with 0 failed devices
gui.js:35 Verifying 1 device, 33% at 33.20 MB/s (total 33.20 MB/s) eta in 31s with 0 failed devices
gui.js:35 Verifying 1 device, 35% at 33.30 MB/s (total 33.30 MB/s) eta in 30s with 0 failed devices
gui.js:35 Verifying 1 device, 37% at 32.80 MB/s (total 32.80 MB/s) eta in 29s with 0 failed devices
gui.js:35 Verifying 1 device, 39% at 32.80 MB/s (total 32.80 MB/s) eta in 28s with 0 failed devices
gui.js:35 Verifying 1 device, 41% at 33.20 MB/s (total 33.20 MB/s) eta in 27s with 0 failed devices
gui.js:35 Verifying 1 device, 44% at 33.10 MB/s (total 33.10 MB/s) eta in 26s with 0 failed devices
gui.js:35 Verifying 1 device, 46% at 33.20 MB/s (total 33.20 MB/s) eta in 25s with 0 failed devices
gui.js:35 Verifying 1 device, 48% at 33.30 MB/s (total 33.30 MB/s) eta in 24s with 0 failed devices
gui.js:35 Verifying 1 device, 50% at 33.20 MB/s (total 33.20 MB/s) eta in 23s with 0 failed devices
gui.js:35 Verifying 1 device, 53% at 33.10 MB/s (total 33.10 MB/s) eta in 22s with 0 failed devices
gui.js:35 Verifying 1 device, 54% at 33.10 MB/s (total 33.10 MB/s) eta in 21s with 0 failed devices
gui.js:35 Verifying 1 device, 57% at 33.20 MB/s (total 33.20 MB/s) eta in 20s with 0 failed devices
gui.js:35 Verifying 1 device, 59% at 33.10 MB/s (total 33.10 MB/s) eta in 19s with 0 failed devices
gui.js:35 Verifying 1 device, 61% at 32.90 MB/s (total 32.90 MB/s) eta in 18s with 0 failed devices
gui.js:35 Verifying 1 device, 63% at 33.10 MB/s (total 33.10 MB/s) eta in 17s with 0 failed devices
gui.js:35 Verifying 1 device, 65% at 33.20 MB/s (total 33.20 MB/s) eta in 16s with 0 failed devices
gui.js:35 Verifying 1 device, 68% at 33.70 MB/s (total 33.70 MB/s) eta in 15s with 0 failed devices
gui.js:35 Verifying 1 device, 70% at 33.20 MB/s (total 33.20 MB/s) eta in 14s with 0 failed devices
gui.js:35 Verifying 1 device, 72% at 33.00 MB/s (total 33.00 MB/s) eta in 13s with 0 failed devices
gui.js:35 Verifying 1 device, 74% at 33.70 MB/s (total 33.70 MB/s) eta in 12s with 0 failed devices
gui.js:35 Verifying 1 device, 76% at 33.00 MB/s (total 33.00 MB/s) eta in 11s with 0 failed devices
gui.js:35 Verifying 1 device, 79% at 33.30 MB/s (total 33.30 MB/s) eta in 10s with 0 failed devices
gui.js:35 Verifying 1 device, 81% at 33.50 MB/s (total 33.50 MB/s) eta in 9s with 0 failed devices
gui.js:35 Verifying 1 device, 83% at 33.20 MB/s (total 33.20 MB/s) eta in 8s with 0 failed devices
gui.js:35 Verifying 1 device, 85% at 33.30 MB/s (total 33.30 MB/s) eta in 7s with 0 failed devices
gui.js:35 Verifying 1 device, 87% at 33.10 MB/s (total 33.10 MB/s) eta in 6s with 0 failed devices
gui.js:35 Verifying 1 device, 89% at 33.50 MB/s (total 33.50 MB/s) eta in 5s with 0 failed devices
gui.js:35 Verifying 1 device, 92% at 33.00 MB/s (total 33.00 MB/s) eta in 3s with 0 failed devices
gui.js:35 Verifying 1 device, 94% at 32.80 MB/s (total 32.80 MB/s) eta in 3s with 0 failed devices
gui.js:35 Verifying 1 device, 96% at 33.30 MB/s (total 33.30 MB/s) eta in 2s with 0 failed devices
gui.js:35 Verifying 1 device, 98% at 32.80 MB/s (total 32.80 MB/s) eta in 1s with 0 failed devices
gui.js:35 Verifying 1 device, 100% at 33.30 MB/s (total 33.30 MB/s) eta in 0s with 0 failed devices
gui.js:46 Thu Sep 01 2022 20:09:38 GMT-0400 (Eastern Daylight Time) Flash error ({“image”:{“size”:1543503872,“name”:“lmde-2-201701-mate-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:1537544192,“size”:2424832,“type”:239,“index”:1}],“extension”:“iso”,“path”:“C:\Linux Mint MATE\lmde-2-201701-mate-64bit.iso”},“drives”:[{“size”:30765219840,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:" USB SanDisk 3.2Gen1 USB Device",“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“6042400f-de7c-4ddb-8963-9392243e2c3e”,“flashInstanceUuid”:“6042400f-de7c-4ddb-8963-9392243e2c3e”,“error”:{“name”:“Error”,“message”:“Unmount failed”,“stack”:“Error: Unmount failed”},“sample”:0.1,“applicationSessionUuid”:“2d0c526a-1e8d-4ede-abf3-8f3d6613c4dd”,“flashingWorkflowUuid”:“d14c9557-0e41-475a-94b5-d3a51960cde0”})
gui.js:46 Finish: 1543503872
gui.js:46 Terminating IPC server
gui.js:46 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:46 Thu Sep 01 2022 20:09:39 GMT-0400 (Eastern Daylight Time) Done ({“image”:{“size”:1543503872,“name”:“lmde-2-201701-mate-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:1537544192,“size”:2424832,“type”:239,“index”:1}],“extension”:“iso”,“path”:“C:\Linux Mint MATE\lmde-2-201701-mate-64bit.iso”},“drives”:[{“size”:30765219840,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive1”,“error”:null,“isReadOnly”:false,“displayName”:“D:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive1”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“D:\”}],“description”:" USB SanDisk 3.2Gen1 USB Device",“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“6042400f-de7c-4ddb-8963-9392243e2c3e”,“status”:“finished”,“flashInstanceUuid”:“6042400f-de7c-4ddb-8963-9392243e2c3e”,“errors”:[{“name”:“Error”,“description”:" USB SanDisk 3.2Gen1 USB Device",“device”:“\\.\PhysicalDrive1”}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:1543503872,“sourceMetadata”:{“size”:1543503872,“name”:“lmde-2-201701-mate-64bit.iso”,“blocks”:[{“blocks”:[{“offset”:0,“length”:1543503872}]}],“blockmappedSize”:1543503872},“sample”:0.1,“applicationSessionUuid”:“2d0c526a-1e8d-4ede-abf3-8f3d6613c4dd”,“flashingWorkflowUuid”:“d14c9557-0e41-475a-94b5-d3a51960cde0”})
gui.js:46 Thu Sep 01 2022 20:09:39 GMT-0400 (Eastern Daylight Time) SafeWebview loaded ({“event”:{“id”:117,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.9&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1662077379774.7878,“resourceType”:“mainFrame”,“ip”:“34.74.170.74”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“33837”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“gzip”],“content-length”:[“7279”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Thu, 01 Sep 2022 14:45:43 GMT”],“etag”:[“"e670fc900558ea52a15f023b2b86a282-ssl-df"”],“link”:[“</webpack-runtime-5904fe791390a12a76e6.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </73ad3401-ecb0d3613fde52e78ca5.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-4b6d12e0d352a4f78d5a.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-cea6bfcc846ea7ff6166.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin”],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01GBXRG9Y4VW1Q2QKDK8436PR8”],“x-xss-protection”:[“1; mode=block”]},“referrer”:“”,“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“2d0c526a-1e8d-4ede-abf3-8f3d6613c4dd”,“flashingWorkflowUuid”:“d14c9557-0e41-475a-94b5-d3a51960cde0”})
the reason for your error is there in the logs.
Your flashing and verification is completed successfully, just the removal of the device ran into an issue. Your device should work fine, go ahead and try booting from it.
I agree that the message on the UI is confusing, it is already in progress to improve on that.
Thanks. I’ll give it a try.
