Config: Dell 16GB, Windows 10, trying to Flash Rasberry Pi OS, 16MB LEXAR SD 200x C10, Read only tab is off. Formatted as FAT32, with Balenaetcher-Portable-1.5.112.exe.
After running Etcher, choosing the OS image file and the SD drive, then Flash. Get error message “Flash failed”. Doesn’t ever seem to actually write.
Console log is:
loudflare.com\/report?s=bG9JyPPW2ZtjtbPCGcOQQQpMhDFh30mYzTpvH4EGFWQgtm9W3Cv30CwAVua2S6WG71inVN3ZEPmb9EMcPOryWbEu20KFGtYQ2TzHZNdpM%2B%2Fp"}],“group”:“cf-nel”,“max_age”:604800}"],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“6f8d6ef38a18a5f125b709c685713ca60bc5c8e4”],“x-github-request-id”:[“EDB6:9F5F:256A400:280E1FF:5FDEB4E6”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-lcy19247-LCY”],“x-timer”:[“S1608449856.531037,VS0,VE1”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“45ed10dc-b1f1-41b0-9cf6-a46d5602d8ac”,“flashingWorkflowUuid”:“582e3333-0dba-4c09-8188-357fed72fa6e”})
gui.js:6038 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:56889 Successfully connected to IPC server: etcher-server-16640, socket root C:\Users\IANMIT~1\AppData\Local\Temp
gui.js:56889 Image: C:\Users\raspios-buster-armhf.img
gui.js:56889 Devices: \.\PhysicalDrive1
gui.js:56889 Umount on success: true
gui.js:56889 Auto blockmapping: true
gui.js:56889 Decompress first: true
gui.js:56889 Sun Dec 20 2020 09:37:48 GMT+0200 (South Africa Standard Time) Flash error ({“image”:{“size”:3972005888,“name”:“raspios-buster-armhf.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:3699376128,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\raspios-buster-armhf.img”},“drives”:[{“size”:63864569856,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“26c9fa9c-1395-429d-b707-1a76c47bfda3”,“flashInstanceUuid”:“26c9fa9c-1395-429d-b707-1a76c47bfda3”,“unmountOnSuccess”:true,“error”:{“name”:“Error”,“message”:“EPERM: operation not permitted, write”,“stack”:“Error: EPERM: operation not permitted, write”,“code”:“EPERM”,“syscall”:“write”,“errno”:-4048},“sample”:0.1,“applicationSessionUuid”:“45ed10dc-b1f1-41b0-9cf6-a46d5602d8ac”,“flashingWorkflowUuid”:“582e3333-0dba-4c09-8188-357fed72fa6e”})
gui.js:56889 Finish: 0
gui.js:56889 Terminating IPC server
gui.js:56889 Flash results Object
gui.js:56889 Sun Dec 20 2020 09:37:52 GMT+0200 (South Africa Standard Time) Done ({“image”:{“size”:3972005888,“name”:“raspios-buster-armhf.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:3699376128,“type”:131,“index”:2}],“extension”:“img”,“path”:“C:\Users\raspios-buster-armhf.img”},“drives”:[{“size”:63864569856,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:"\\.\PhysicalDrive1",“error”:null,“isReadOnly”:false,“displayName”:“F:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:"\\.\PhysicalDrive1",“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“F:\”}],“description”:“Mass Storage Device USB Device”,“isUAS”:false,“partitionTableType”:“mbr”}],“driveCount”:1,“uuid”:“26c9fa9c-1395-429d-b707-1a76c47bfda3”,“status”:“finished”,“flashInstanceUuid”:“26c9fa9c-1395-429d-b707-1a76c47bfda3”,“unmountOnSuccess”:true,“errors”:[{“name”:“Error”,“description”:“Mass Storage Device USB Device”,“code”:“EPERM”,“syscall”:“write”,“errno”:-4048,“device”:"\\.\PhysicalDrive1"}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:0,“sourceMetadata”:{“size”:3972005888,“name”:“raspios-buster-armhf.img”,“blocks”:[{“blocks”:[{“offset”:0,“length”:324009984}]},{“blocks”:[{“offset”:406847488,“length”:152043520}]},{“blocks”:[{“offset”:563085312,“length”:1692401664}]},{“blocks”:[{“offset”:2256535552,“length”:254803968}]},{“blocks”:[{“offset”:2522873856,“length”:158334976}]},{“blocks”:[{“offset”:2682257408,“length”:267386880}]},{“blocks”:[{“offset”:2950692864,“length”:2097152}]},{“blocks”:[{“offset”:2953838592,“length”:16777216}]},{“blocks”:[{“offset”:2977955840,“length”:5242880}]},{“blocks”:[{“offset”:2984247296,“length”:39845888}]},{“blocks”:[{“offset”:3026190336,“length”:1048576}]},{“blocks”:[{“offset”:3028287488,“length”:1048576}]},{“blocks”:[{“offset”:3031433216,“length”:2097152}]},{“blocks”:[{“offset”:3035627520,“length”:211812352}]},{“blocks”:[{“offset”:3248488448,“length”:204472320}]},{“blocks”:[{“offset”:3460300800,“length”:40894464}]},{“blocks”:[{“offset”:3502243840,“length”:16777216}]},{“blocks”:[{“offset”:3524263936,“length”:1048576}]},{“blocks”:[{“offset”:3527409664,“length”:25165824}]},{“blocks”:[{“offset”:3557818368,“length”:28311552}]},{“blocks”:[{“offset”:3628072960,“length”:1048576}]},{“blocks”:[{“offset”:3896508416,“length”:1048576}]}],“blockmappedSize”:3447717888},“sample”:0.1,“applicationSessionUuid”:“45ed10dc-b1f1-41b0-9cf6-a46d5602d8ac”,“flashingWorkflowUuid”:“582e3333-0dba-4c09-8188-357fed72fa6e”})
gui.js:56889 Sun Dec 20 2020 09:37:54 GMT+0200 (South Africa Standard Time) SafeWebview loaded ({“event”:{“id”:116,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.5.112&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1608449874360.7112,“resourceType”:“mainFrame”,“ip”:“54.207.147.214”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“128054”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“br”],“content-length”:[“6265”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Fri, 18 Dec 2020 20:03:40 GMT”],“etag”:["“37eea542ff0840d31f003c1bb78bdd3e-ssl-df”"],“link”:["</webpack-runtime-bbe89a9b0c676dfe6688.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-1412a250c868c0a8c32e.js>; rel=preload; as=script, </73ad3401-b34093a8033d990846f8.js>; rel=preload; as=script, </532a2f07-79d7d47f8c4538117bc1.js>; rel=preload; as=script, </app-9a4ffca057ba7b7eb646.js>; rel=preload; as=script, </c943faba-8401ef931f889cf944b7.js>; rel=preload; as=script, </af13d906-35b0ceec0469366ea95d.js>; rel=preload; as=script, </ec1189df-f1a321eba12a2bb0c7ab.js>; rel=preload; as=script, </a9a7754c-8c1c986c04a5e7e0eb7d.js>; rel=preload; as=script, </4cb05eeb-b3d75e0ea6d5bf23eefa.js>; rel=preload; as=script, </231dbb27-4338284bbe58d6dfdf6d.js>; rel=preload; as=script, </09701b4e-af614bef3348fcdee886.js>; rel=preload; as=script, </8adc965a-a7876456b8d16e3cf929.js>; rel=preload; as=script, </42cf64af-f20bd93ce07ef388a461.js>; rel=preload; as=script, </commons-d2f65fa441a6b18b951b.js>; rel=preload; as=script, </fa5ad257d571af33d737afaa118648b294b3ca41-57c9d77daebffbfca154.js>; rel=preload; as=script, </1f9101bfa6ab6b5c77f1b7191fb4987950aee8e9-2a13ff60a3f77104df6a.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-278df0bb34cef76decdb.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin"],“referrer-policy”:[“same-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“cd8ce9a7-b112-4873-b0e7-96a8bbb28422-792369”],“x-xss-protection”:[“1; mode=block”]},“referrer”:"",“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“45ed10dc-b1f1-41b0-9cf6-a46d5602d8ac”,“flashingWorkflowUuid”:“582e3333-0dba-4c09-8188-357fed72fa6e”})
