I’m trying to install zigbee2mqtt software inside balena os but I always get an adapter error:
Zigbee2MQTT:error 2022-10-09 01:26:05: Error while starting zigbee-herdsman
[Logs] [2022-10-9 1:26:05] [zigbee2mqtt] Zigbee2MQTT:error 2022-10-09 01:26:05: Failed to start zigbee
[Logs] [2022-10-9 1:26:05] [zigbee2mqtt] Zigbee2MQTT:error 2022-10-09 01:26:05: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[Logs] [2022-10-9 1:26:05] [zigbee2mqtt] Zigbee2MQTT:error 2022-10-09 01:26:05: Exiting...
[Logs] [2022-10-9 1:26:06] [zigbee2mqtt] Zigbee2MQTT:error 2022-10-09 01:26:06: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[Logs] [2022-10-9 1:26:06] [zigbee2mqtt] at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
[Logs] [2022-10-9 1:26:06] [zigbee2mqtt] at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
[Logs] [2022-10-9 1:26:06] [zigbee2mqtt] at Zigbee.start (/app/lib/zigbee.ts:58:27)
[Logs] [2022-10-9 1:26:06] [zigbee2mqtt] at Controller.start (/app/lib/controller.ts:101:27)
[Logs] [2022-10-9 1:26:06] [zigbee2mqtt] at start (/app/index.js:109:5)
I checked ports and they seem ok.
Mi configuration.yaml it’s like this:
# Home Assistant integration (MQTT discovery)
homeassistant: false
# allow new devices to join
permit_join: false
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: z2mpi
# MQTT server URL
server: 'mqtt://192.168.0.6'
# MQTT server authentication, uncomment if required:
# user: my_user
# password: my_password
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: /dev/ttyACM0
frontend:
port: 5000
Docker-compose.yml is like that:
version: '2'
volumes:
volume_zigbee2mqtt:
services:
mqtt:
image: arm32v6/eclipse-mosquitto
restart: always
ports:
- 1883:1883
zigbee2mqtt:
build: zigbee2mqtt
restart: always
volumes:
- volume_zigbee2mqtt:/app/data
ports:
- "8008:8008"
devices:
- /dev/ttyACM0:/dev/ttyACM0
environment:
- DATA=/app/data
- TZ=Europe/Madrid
I’m testing in intel nuc.
Can you help me?
Regards.
