exFAT support in *ANY* base image?
Is there a base image that already has exFAT support?
I have tried several ways to add exFAT to a debian image, but with no luck. Here is one attempt:
FROM balenalib/%%BALENA_MACHINE_NAME%%-python:3.11.2-bookworm-build
RUN apt-get update -q -y
RUN install_packages software-properties-common
RUN add-apt-repository "deb http://archive.ubuntu.com/ubuntu jammy universe" # 22.04
RUN install_packages exfat-fuse exfat-utils
I keep getting the error:
[vnc-app]  E: Package 'exfat-utils' has no installation candidate
Any help would be much appreciated!
Hello @craftonix_aa
let’s go trough your Dockerfile and see what you’re doing:
You are getting Python 3.11.2 built on Debian 12/Bookworm
Then you add an Ubuntu repositorys to your Debian Bookworm installation. You should never do this, especially with file system drivers or similar kernel-near things.
Finally you want to install exfat-fuse and exfat-utils.
The error that comes back is basically showing you the correct way:
This means there is no package for exfat-utils available for Debian Bookworm, so you cannot install it.
If you have a look at the Debian Repo:
https://packages.debian.org/search?suite=default&section=all&arch=any&searchon=names&keywords=exfat-
You will find that extfat-fuse is available for Debian Bookworm, but exfat-utils not.
You can also see that the older stable version, Debian Bullseye has both versions available…
So if you need to use both packages, try to find a Python version build on Bullseye and just use that and install both packages (without adding Ubuntu Repos) and then it should work.
Cheers
