Etcher has been working fine but now fails every time, even after removal and reinstall.
Here is a copy of log.
Failed to load resource: net::ERR_FILE_NOT_FOUND
electron/js2c/renderer_init.js:13 (electron) The remote module is deprecated. Use GitHub - electron/remote: Bridge JavaScript objects from the main process to the renderer process in Electron. instead.
gui.js:364 _____ _ _
| | | | | | ___ _ __
| || / | ’ \ / _ \ '|
_/ ____|| ||___||
Interested in joining the Etcher team?
Drop us a line at join+etcher@balena.io
Version = 1.10.6, Type = nsis
gui.js:46 Wed Dec 14 2022 19:15:42 GMT-0800 (Pacific Standard Time) Application start ({“packageType”:“nsis”,“version”:“1.10.6”,“sample”:0.1,“applicationSessionUuid”:“b6b68e7f-70dd-4705-a5e5-d37782017609”,“flashingWorkflowUuid”:“64eb5b2b-f666-4df8-9cc2-3d5b522f9541”})
gui.js:46 Wed Dec 14 2022 19:16:40 GMT-0800 (Pacific Standard Time) Open image selector ({“sample”:0.1,“applicationSessionUuid”:“b6b68e7f-70dd-4705-a5e5-d37782017609”,“flashingWorkflowUuid”:“64eb5b2b-f666-4df8-9cc2-3d5b522f9541”})
gui.js:46 Wed Dec 14 2022 19:16:54 GMT-0800 (Pacific Standard Time) Select image ({“image”:{“size”:2415585280,“name”:“linuxmint-21-xfce-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:32768,“size”:2411169792,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“6D4F3559-353E-4F68-9E81-073EBFC45977”,“name”:“ISO9660”,“index”:1},{“offset”:2411202560,“size”:4349952,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“6D4F3559-353E-4F68-9E82-073EBFC45977”,“name”:“Appended2”,“index”:2}],“extension”:“iso”,“path”:“C:\Users\randy\Downloads\linuxmint-21-xfce-64bit.iso”,“logo”:false,“blockMap”:false},“sample”:0.1,“applicationSessionUuid”:“b6b68e7f-70dd-4705-a5e5-d37782017609”,“flashingWorkflowUuid”:“64eb5b2b-f666-4df8-9cc2-3d5b522f9541”})
gui.js:46 Wed Dec 14 2022 19:16:58 GMT-0800 (Pacific Standard Time) Flash ({“image”:{“size”:2415585280,“name”:“linuxmint-21-xfce-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:32768,“size”:2411169792,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“6D4F3559-353E-4F68-9E81-073EBFC45977”,“name”:“ISO9660”,“index”:1},{“offset”:2411202560,“size”:4349952,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“6D4F3559-353E-4F68-9E82-073EBFC45977”,“name”:“Appended2”,“index”:2}],“extension”:“iso”,“path”:“C:\Users\randy\Downloads\linuxmint-21-xfce-64bit.iso”},“drives”:[{“size”:31266439168,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“Lexar microSD RDR USB Device”,“isUAS”:false,“partitionTableType”:null}],“driveCount”:1,“uuid”:“4655defc-9e5f-4b46-9b07-5c4b5f7af5d1”,“status”:“started”,“flashInstanceUuid”:“4655defc-9e5f-4b46-9b07-5c4b5f7af5d1”,“sample”:0.1,“applicationSessionUuid”:“b6b68e7f-70dd-4705-a5e5-d37782017609”,“flashingWorkflowUuid”:“64eb5b2b-f666-4df8-9cc2-3d5b522f9541”})
gui.js:46 {“stack”:“Error: Error invoking remote method ‘disable-screensaver’: No handler registered for ‘disable-screensaver’\n at EventEmitter.i.invoke (electron/js2c/renderer_init.js:73:529)”,“message”:“Error invoking remote method ‘disable-screensaver’: No handler registered for ‘disable-screensaver’”}
gui.js:46 Elevating command: C:\Users\randy\AppData\Local\Programs\balena-etcher\balenaEtcher.exe C:\Users\randy\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js
gui.js:35 0 devices, 0% at 0.00 MB/s (total 0.00 MB/s) with 0 failed devices
gui.js:46 Wed Dec 14 2022 19:16:59 GMT-0800 (Pacific Standard Time) SafeWebview loaded ({“event”:{“id”:1,“url”:“https://www.balena.io/etcher/featured 200”,“statusCode”:200,“responseHeaders”:{“access-control-allow-origin”:[“*”],“age”:[“283”],“alt-svc”:[“h3=":443"; ma=86400, h3-29=":443"; ma=86400”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“779c060fdad5ef67-PDX”],“content-encoding”:[“br”],“content-type”:[“text/html; charset=utf-8”],“date”:[“Thu, 15 Dec 2022 03:16:59 GMT”],“expires”:[“Wed, 14 Dec 2022 14:56:15 GMT”],“last-modified”:[“Mon, 14 Nov 2022 17:08:20 GMT”],“nel”:[“{"success_fraction":0,"report_to":"cf-nel","max_age":604800}”],“report-to”:[“{"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=tdn4sAISxY1%2Bb7kV6aGCJoJBjzBywNYnXofSGZwjIScAY8EDytH1M62MK7EKRrZOMw8fIsjlA7Xgm08N86aJfjNIg6XDEwwvmG4nEjL4uZcHn7AMVwK%2BqZGH7Q36ls%2BcMNU%2F"}],"group":"cf-nel","max_age":604800}”],“server”:[“cloudflare”],“vary”:[“Accept-Encoding”],“via”:[“1.1 varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“3”],“x-fastly-request-id”:[“29d07b95320ca28d765e741b220fff259a414c3f”],“x-github-request-id”:[“34DA:4EE0:6BBB27:7B1FC8:6399E1B6”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-pdx12327-PDX”],“x-timer”:[“S1671074220.512687,VS0,VE0”]},“referrer”:“”,“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“b6b68e7f-70dd-4705-a5e5-d37782017609”,“flashingWorkflowUuid”:“64eb5b2b-f666-4df8-9cc2-3d5b522f9541”})
gui.js:46 Wed Dec 14 2022 19:17:00 GMT-0800 (Pacific Standard Time) TypeError: Converting circular structure to JSON
→ starting at object with constructor ‘Object’
— property ‘top’ closes the circle
gui.js:46 Successfully connected to IPC server: etcher-server-1732, socket root C:\Users\randy\AppData\Local\Temp
gui.js:46 Image: C:\Users\randy\Downloads\linuxmint-21-xfce-64bit.iso
gui.js:46 Devices: \.\PhysicalDrive2
gui.js:46 Auto blockmapping: true
gui.js:46 Decompress first: true
gui.js:46 Wed Dec 14 2022 19:17:06 GMT-0800 (Pacific Standard Time) Flash error ({“image”:{“size”:2415585280,“name”:“linuxmint-21-xfce-64bit.iso”,“hasMBR”:true,“partitions”:[{“offset”:32768,“size”:2411169792,“type”:“EBD0A0A2-B9E5-4433-87C0-68B6B72699C7”,“guid”:“6D4F3559-353E-4F68-9E81-073EBFC45977”,“name”:“ISO9660”,“index”:1},{“offset”:2411202560,“size”:4349952,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“6D4F3559-353E-4F68-9E82-073EBFC45977”,“name”:“Appended2”,“index”:2}],“extension”:“iso”,“path”:“C:\Users\randy\Downloads\linuxmint-21-xfce-64bit.iso”},“drives”:[{“size”:31266439168,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“E:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“E:\”}],“description”:“Lexar microSD RDR USB Device”,“isUAS”:false,“partitionTableType”:null}],“driveCount”:1,“uuid”:“4655defc-9e5f-4b46-9b07-5c4b5f7af5d1”,“flashInstanceUuid”:“4655defc-9e5f-4b46-9b07-5c4b5f7af5d1”,“error”:{“name”:“Error”,“message”:“EPERM: operation not permitted, write”,“stack”:“Error: EPERM: operation not permitted, write”,“code”:“EPERM”,“syscall”:“write”,“errno”:-4048},“sample”:0.1,“applicationSessionUuid”:“b6b68e7f-70dd-4705-a5e5-d37782017609”,“flashingWorkflowUuid”:“64eb5b2b-f666-4df8-9cc2-3d5b522f9541”})
gui.js:46 Finish: 0
