I am using the latest BalenaOS + openBalena and am currently trying to update my environment variables using this method.
My request looks like this:
curl --request PUT \
--url "https://api.<URL>/v6/device_environment_variable(device='DEVICE_ID',name='whoa')" \
--header 'Authorization: Bearer XXXXXXXXXXX' \
--header 'Content-Type: application/json' \
--data '{"value": "todayz"}'
When I run this command I am getting the error: “Can only call getAffectedIds with PATCH/DELETE requests”.
Any thoughts on what is going on? This should just delete and insert the new variable named “whoa” with value “todayz”
