error on building my own generic balena image
i am very new to the balena-os build an i am trying to build my own custom generic balena x86_64 image with the help of this page:
my steps are:
git clone https://github.com/balena-os/balena-generic
cd balena-generic/
git submodule update --init --recursive
and then running
./balena-yocto-scripts/build/barys -m genericx86-64-ext
after some time i get the following error:
ERROR: libpcre-8.44-r0 do_package_qa: QA Issue: libpcre: The install log indicates that host include and/or library paths were used.
Please check the log ‘/workspaces/yocto/2/balena-generic/build/tmp/work/core2-64-poky-linux/libpcre/8.44-r0/temp/log.do_install’ for more information. [install-host-path]
ERROR: libpcre-8.44-r0 do_package_qa: QA run found fatal errors. Please consider fixing them.
ERROR: Logfile of failure stored in: /workspaces/yocto/2/balena-generic/build/tmp/work/core2-64-poky-linux/libpcre/8.44-r0/temp/log.do_package_qa.3485810
ERROR: Task (/workspaces/yocto/2/balena-generic/build/…/layers/poky/meta/recipes-support/libpcre/libpcre_8.44.bb:do_package_qa) failed with exit code ‘1’
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
so i can’t even get the normal balena-generic image building process working.
What is the Problem? Am i something missing? How can this be resolved?
Hi, did you follow the steps in the Yocto setup? https://www.yoctoproject.org/docs/current/brief-yoctoprojectqs/brief-yoctoprojectqs.html
From the link you mentioned:
you will first need to make sure you have a working Yocto environment setup
Yocto is the underlying technology used to build BalenaOS, and it’s BalenaOS is able to run on so many different device types.
yes i did follow it step by step.
My build system looks like this:
  • Ubuntu 22.04 Jammy
  • installed packages like stated in Welcome to the Yocto Project Documentation — The Yocto Project ® 4.0.999 documentation gawk wget git-core diffstat unzip texinfo gcc-multilib build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev pylint3 xterm
  • also tried to run source oe-init-build-env, but error stays the same.
  • i am building in docker container
I think there is something i missed in the documentation. I am using Ubuntu 22.04, but it is not in the supported linux distributions section of the documentation. i’ll have a try with Debian Buster later this day.
Changed my OS from Ubuntu 22.04 to Debian, compiling and image creation is now working as expected. Thanks for all the help.
Thank you for sharing the solution @SqaureRoot
