hi
when i execute “balena push XXX”, I got the error message
[Info] Starting build for first-fleet, user g_cf
[Info] Dashboard link: balena dashboard
[Info] Building on 28fcfdc
[Info] No suitable previous release for caching, skipping cache pull
[wifi-repeater] Step 1/12 : FROM balenalib/raspberrypi5-node:12-build as builder
[wifi-repeater] manifest for balenalib/raspberrypi5-node:12-build not found: manifest unknown: manifest unknown
[Error] Service: wifi-repeater
[Error] Error: manifest for balenalib/raspberrypi5-node:12-build not found: manifest unknown: manifest unknown
[Info] Built on 28fcfdc
Remote build failed
I don’t know what happen!
Hello @ycf first of all welcome to the balena community.
Is there any specific project where you need NodeJS v12?
Could you please try if using this base image in the container it works? balenalib/raspberrypi5-node:20-build or 19-build or the latest? You can find here more base images for Raspberry Pi 5 Node!
Let us know if that works!
