Error: grpc: the connection is unavailable
Hello, today I got builder error during resin push.
[Error] Service: main
[Error] Error: grpc: the connection is unavailable
But after a few tries it was successfully built and uploaded.
Again as mentioned in my last post (Full app downoad after "Error: Builder disconnected" message) the app was downloaded by device fully, not only upgrded part
I am getting this also with my own projects and sample project https://github.com/influxdata/resin-influx
Seems like there are some issues although nothing showing on https://status.resin.io/
Thanks for the reports, we’re looking into it
Thanks again for the reports.
Our team has been able to locate and look into the transient GRPC communication issue which occurred on one of our builder instances from 22:00 to 13:00 BST. As it only occurred on one of our build instances it only affected a % of all builds, and fortunately repeat builds seem to have gone through during that timeframe.
We have resolved the issue, and will continue to work to prevent repetition.
Hey chrischabot, the same issue is happening to me today
[main] grpc: the connection is unavailable
Broken for me too on arm01.
Works ok when arm02 builds it.
I am encountering this error when trying to connect to a container via SSH on one of our devices currently. Can’t say for sure if it is device specific or not yet. But I suspect its a different issue, since the device is generally doing weird stuff, like randomly restarting all containers, currently.
Happening to me today. Interesting that the first post was exactly a year ago - is there some pattern there?
I am getting the same issue repeatedly when building with arm01
Today I got this message again. Is April 18 a “magic date”?
Looking on masseges in this thread. Seams, every 18th day of each month could be a problem
UPD:
yesterday I got failed build with this message:
“E: Some index files failed to download. They have been ignored, or old ones used instead.”
I have tried to build the same app on another balena account - and it was successfull.
Today i have gprc error on my account
Having it all night now as well. Docker files haven’t changed, but something on the platform has definitely gone bad…
Yep, also running into build problems with our containers. Was able to build some of our services locally though.
Hey @mpfluger, @letrich, @jayatrbt, @ejohnso49
I’m so sorry for the inconvenience. Our team has been able to locate and look into the issue. In our builders, docker-containerd process fails, and the parent process (dockerd) fails to detect the failure or respawn the child process, resulting in this rpc error when trying to reach it
I am seeing this currently.
[broker]   Successfully built a6eaa9e4610c
[gateway]   ---> Running in 23ba3eb2f154
[gateway]  Removing intermediate container 23ba3eb2f154
[gateway]  grpc: the connection is unavailable
[app]      Step 1/9 : FROM wlisac/generic-armv7ahf-swift:4.2.3
[app]       ---> 6957cfcc32ff
[app]      Step 2/9 : RUN install_packages libmosquitto-dev
[app]       ---> Running in 1fa301ec83ea
[app]      Removing intermediate container 1fa301ec83ea
[Info]     Uploading images
[app]      grpc: the connection is unavailable
[Success]  Successfully uploaded images
[Error]      Service: app
[Error]      Service: undefined
[Error]        Error: Information not available
[Error]      Service: gateway
Remote build failed
I’m seeing this now, too.
[Info]     Building on arm01
[Info]     Pulling previous images for caching purposes...
[Success]  Successfully pulled cache images
[main]     Step 1/8 : FROM wlisac/raspberrypi3-swift:5.0.1-build AS build
[main]      ---> 9a965840315a
[main]     Step 2/8 : WORKDIR /app
[main]      ---> 6732b373b67d
[main]     Removing intermediate container 4cfd938ec67d
[main]     Step 3/8 : COPY . ./
[main]      ---> 399a6fb4e975
[main]     Removing intermediate container b20299fea4a1
[main]     Step 4/8 : RUN swift build
[main]      ---> Running in fb49cb372a74
[main]     Removing intermediate container fb49cb372a74
I just had a successful build of the same project on arm03. Maybe it’s specific to arm01?
Hey @wlisac thanks for reporting, I’m investigating arm01 now, but if you retry and get a different builder it should be working ok.
Taking a quick look, it seems to be a bug in the docker daemon (or one of it’s supporting modules, such as containerd). A restart of the daemon does fix things, but we’re investigating the root cause too. You should be able to push to any arm host now. Thanks again for the report!
Thanks @CameronDiver – looks good now. And thanks to @incanus for noticing it first. :slight_smile:
The issue still seems present…
[main]      ---> Running in d8bc5984986e
[main]     Removing intermediate container d8bc5984986e
Remote build failed
If you need help, don't hesitate in contacting us at:
  GitHub: https://github.com/balena-io/balena-cli/issues/new
  Forums: https://forums.balena.io
