When I deploy project, some wrong alway show. How can i resovle this problem?
root@ubuntu:/opt/multicontainer-getting-started# DEBUG=1 balena deploy myApp --logs --source . --emulated
Debug: original argv0=“node” argv=[/root/.nvm/versions/node/v8.14.1/bin/node,/root/.nvm/versions/node/v8.14.1/bin/balena,deploy,myApp,–logs,–source,.,–emulated] length=8
[Debug] Parsing input…
[Debug] Loading project…
[Debug] Resolving project…
[Info] Compose file detected
[Debug] Creating project…
[Info] Building for armv7hf/raspberrypi3
[Build] Building services…
[Build] frontend Preparing…
[Build] data Preparing…
[Info] Emulation is enabled
[Debug] Found build tasks:
[Debug] frontend: build [./frontend]
[Debug] data: build [./data]
[Debug] Resolving services with [raspberrypi3|armv7hf]
[Debug] Found project types:
[Debug] frontend: Dockerfile.template
[Debug] data: Dockerfile.template
[Debug] Prepared tasks; building…
[Build] data Step 1/7 : FROM balenalib/raspberrypi3-debian-node:10-stretch-run
[Build] data —> f28dbac4045d
[Build] frontend Step 1/12 : FROM balenalib/raspberrypi3-debian-node:10-stretch-run
[Build] frontend —> f28dbac4045d
[Build] data Step 2/7 : COPY [".balena/qemu-execve","/tmp/qemu-execve"]
[Build] data —> Using cache
[Build] data —> 9227ebfc83ef
[Build] data Step 3/7 : WORKDIR /usr/src/app
[Build] data —> ba148e675876
[Build] data Step 4/7 : COPY [“package.json”,“package.json”]
[Build] frontend Step 2/12 : COPY [".balena/qemu-execve","/tmp/qemu-execve"]
[Build] frontend —> Using cache
[Build] frontend —> 9227ebfc83ef
[Build] frontend Step 3/12 : WORKDIR /usr/src/app
[Build] data —> 226bb4ba2b84
[Build] frontend —> ba148e675876
[Build] Built 2 services in 0:02
[Error] Deploy failed
SecretRemovalError: The command ‘/bin/sh -c apk update && apk add jq’ returned a non-zero code: 1
at Object. (/root/.nvm/versions/node/v8.14.1/lib/node_modules/balena-cli/node_modules/resin-multibuild/build/index.js:122:19)
at Generator.throw ()
at rejected (/root/.nvm/versions/node/v8.14.1/lib/node_modules/balena-cli/node_modules/resin-multibuild/build/index.js:5:65)
at
w.
