Getting error during balena build
Why do I get this error when I do a balena build usin the below command ?
balena build --deviceType beaglebone-black --arch armv7hf --emulated
I am able to build it locally using the docker build.
[Build] main [====================>] 100% Step 20/20: make: *** [binary/lora] Error 1
[Error] Build failed
Error: The command ‘/tmp/qemu-execve -execve /bin/sh -c make’ returned a non-zero code: 2
at Stream. (/snapshot/versioned-source/node_modules/resin-docker-build/build/builder.js:178:23)
at Stream.stream.write (/snapshot/versioned-source/node_modules/through/index.js:26:11)
at Stream.ondata (internal/streams/legacy.js:15:31)
at Stream.emit (events.js:189:13)
at Stream.EventEmitter.emit (domain.js:441:20)
at drain (/snapshot/versioned-source/node_modules/through/index.js:36:16)
at Stream.stream.queue.stream.push (/snapshot/versioned-source/node_modules/through/index.js:45:5)
at Parser.exports.parse.parser.onToken (/snapshot/versioned-source/node_modules/JSONStream/index.js:132:18)
at Parser.proto.write (/snapshot/versioned-source/node_modules/jsonparse/jsonparse.js:135:34)
at Stream. (/snapshot/versioned-source/node_modules/JSONStream/index.js:23:12)
at IncomingMessage.ondata (_stream_readable.js:689:20)
at IncomingMessage.emit (events.js:189:13)
at IncomingMessage.EventEmitter.emit (domain.js:441:20)
at addChunk (_stream_readable.js:284:12)
at readableAddChunk (_stream_readable.js:265:11)
at IncomingMessage.Readable.push (_stream_readable.js:220:10)
at HTTPParser.parserOnBody (_http_common.js:122:22)
at Socket.socketOnData (_http_client.js:442:20)
at Socket.emit (events.js:189:13)
at Socket.EventEmitter.emit (domain.js:441:20)
at Socket.Readable.push (_stream_readable.js:220:10)
at Pipe.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
Is it because of the size of image?
