[Success]  Image created successfully
[Info]     Verifying image integrity...
[Success]  Image passed integrity checks!
[Info]     Pulling old image for delta generation
[==================================================>] 100%
[Success]  Cached image pulled in 1 second
[Info]     Generating delta for faster device updates
[Success]  Delta generated in 2 seconds; size: 496.24 KB
[Info]     To enable deltas, see https://docs.resin.io/runtime/delta/
[Info]     Uploading image to registry...
[===============================>                   ] 62%[Error]    Build failed: denied: requested access to the resource is deniedWe are just triaging this issue, as it was brought up by our internal tests too. Looks like there’s a potential fix being added soon.
In the meantime can you try to repush? This issue should happen only sporadically (just a few % of the cases in our tests), so a repush should succeed.
Sure, repush did succeed, but I thought it was worth reporting it.
Maybe just changing the error message to ask for a repush would be good enough for a fix ?
Thanks for the report for sure.
Getting the fix out is likely quicker than updating the error message, though. Sorry about the inconvenience.
We’ve seen a sporadic error that could be related to this as well. Has the fix discussed above been implemented?
Part of the log:
remote: error: hook declined to update refs/heads/master To headless@git.resin.io:project_xyz/xyz.git
! [remote rejected] HEAD -> master (hook declined)
error: failed to push some refs to 'headless@git.resin.io:project_xyz/xyz.git'And once again :
[Build]    Successfully tagged registry2.resin.io:443/fleetmanagement/d0d0b834016850d270c1742a5279e41158fa45b5:latest
[=================>                                 ] 34%[Error]    Build failed: denied: requested access to the resource is denied
A “repush” fixed the error, soI still think it wouldn’t be a big deal if there was a suggestion message asking to repush (in case defintive fix is not possible).
@Tristan107 We just merged a fix for this error, and it should be merged today or tomorrow. It’s caused by docker requesting access to images that do not belong to the user, to use as a cache for the push. I’ll update this post when the fix is deployed.
Hey @Tristan107 just to let you know, we’ve deployed a fix for this, please do get in touch if you experience the same issue.
