I’m running an app based on https://github.com/balena-io/balena-electronjs. I’m using the Raspberry Pi 7" touch screen as the display.
My problem is that the touch screen / touch events are sometimes unresponsive and don’t register any presses. If I use a regular mouse, I can’t reproduce this behaviour, everything works and everything is as responsive as intended.
Sometimes the touch screen doesn’t react at all to presses, sometimes it seems to register a new press on the last registered button, even if I’m pressing a completely different button. This behaviour is not consistent, however, so I can’t pinpoint the root cause.
The behaviour seems to start after a bit of idling, but I’m not sure about this. After I manage to get one successful press, everything works fine for a while.
The screen seems to be slightly more responsive when the cursor is visible (i.e. removing the -nocursor flag from start.sh script), but I might be imagining…
I haven’t yet experimented much with other settings such as enabling hw acceleration or increasing gpu memory, but since the external mouse works, I don’t think the problem lies there (I could be wrong…)
Any hints/tips/pointers on how I should start debugging this?
