Am trying to deploy a Java application that uses pi4j which has dependency on the native library http://wiringpi.com/download-and-install/. When I try to run a program simple LED blinker it fails with message
wiringPiSetup: Unable to open /dev/mem or /dev/gpiomem: No such file or directory.
Aborting your program because if it can not access the GPIO
hardware then it most certianly won't work
Try running with sudo?
If you’re using a single container application, then by default, containers are privileged. However, it sounds like you’re using a multicontainer application. You don’t have to run this privileged however, for most hardware. There’s a guide on how to do this here.
@hedss - thanks for the link . excuse me for my ignorance in this IoT side of world… just getting myself into it
no I don’t run multi container app, its single container only. So if I understand you correctly settings as show in the reference links is good for Single container as well and I can remove privileged settings?
If you’re not using a multicontainer app with a docker-compose.yml file, then you should be able to access the /dev/mem and /dev/gpiomem from your single container without the need for privileged mode, that’s correct (and the balena Dashboard for your device should show a single service, named main, running).
If you are using a docker-compose.yml file, then you’ll either need to make the service privileged (as you mention above), or you’ll need to use the devices and cap_add sections of the docker-compose.yml as mentioned in the guide!
