Hello
I have a problem with disabling dtoverlay vc4-kms-v3d
Any setting causes that this dtoverlay still appears on rpi4
I have to disable it, cause it disallow me to use particular monitors
This is not working
Empty is not working:
08.06.20 11:49:39 (+0200) Applied boot config: {“hdmi_force_hotplug”:“1”,“disable_overscan”:“1”,“framebuffer_height”:“780”,“framebuffer_width”:“1280”,“gpu_mem”:“396”,“arm_64bit”:“1”,“avoid_warnings”:“1”,“disable_splash”:“1”,“dtparam”:[“i2c_arm=on”,“spi=on”,“audio=on”],“dtoverlay”:[“vc4-fkms-v3d”]}
Test:
Should i raise an issue somewhere?
zvin
4
Why? It’s not required for rpi4 and sometimes is breaker for usabilities
I think that for rpi4-64 only RESIN_HOST_CONFIG_arm_64bit should be enabled
I see that it’s related to https://github.com/balena-io/balena-supervisor/issues/1171
But definitely there should be option to disable this overlay.
It’s not even related to 64 bit rpi version, but the graphics
vc4-fkms-v3d is disabled very often - causes black screen and no hdmi output in some situations
I just raised an issue here:
zvin
6
Thanks for creating the issue, I’ve contacted the team about it. We’ll keep you posted.
JSReds
10
Hi there,
we would like to inform you that the issue you have mentioned has been closed https://github.com/balena-io/balena-supervisor/issues/1404 and the related issue you can find in comments has been merged.
