Understood. I won’t be able to try another power source until tomorrow at least, but I can give you the logs for now.
dmroot@fb1282d:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.98 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Mon Jun 17 12:13:38 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x33800000
[ 0.000000] On node 0 totalpages: 212992
[ 0.000000] free_area_init_node: node 0, pgdat 8138ae00, node_mem_map b30a4000
[ 0.000000] Normal zone: 1872 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 212992 pages, LIFO batch:31
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x448 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu @b304c000 s38796 r8192 d22644 u69632
[ 0.000000] pcpu-alloc: s38796 r8192 d22644 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 211120
[ 0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 console=ttyS0,115200 rootfstype=ext4 rootwait root=PARTUUID=1e5c56fe-02 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 815284K/851968K available (8192K kernel code, 600K rwdata, 2288K rodata, 7168K init, 704K bss, 28492K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xb4800000 - 0xff800000 (1200 MB)
lowmem : 0x80000000 - 0xb4000000 ( 832 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80900000 (9184 kB)
.init : 0x80c00000 - 0x81300000 (7168 kB)
.data : 0x81300000 - 0x8139622c ( 601 kB)
.bss : 0x8139e624 - 0x8144e7b0 ( 705 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 27474 entries in 81 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000023] Switching to timer-based delay loop, resolution 52ns
[ 0.000281] Console: colour dummy device 80x30
[ 0.000847] console [tty1] enabled
[ 0.000892] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000934] pid_max: default: 32768 minimum: 301
[ 0.001266] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001302] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002223] CPU: Testing write buffer coherency: ok
[ 0.002695] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003150] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003299] Hierarchical SRCU implementation.
[ 0.004035] smp: Bringing up secondary CPUs …
[ 0.004852] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005691] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006468] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006573] smp: Brought up 1 node, 4 CPUs
[ 0.006648] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.006669] CPU: All CPU(s) started in HYP mode.
[ 0.006687] CPU: Virtualization extensions available.
[ 0.007631] devtmpfs: initialized
[ 0.018508] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.018776] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018822] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.019437] pinctrl core: initialized pinctrl subsystem
[ 0.020273] NET: Registered protocol family 16
[ 0.022919] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.027606] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.027639] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.027874] Serial: AMBA PL011 UART driver
[ 0.029637] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.030145] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.061524] bcm2835-dma 3f007000.dma: DMA legacy API manager at b4813000, dmachans=0x1
[ 0.063023] SCSI subsystem initialized
[ 0.063266] usbcore: registered new interface driver usbfs
[ 0.063343] usbcore: registered new interface driver hub
[ 0.063444] usbcore: registered new device driver usb
[ 0.070090] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-11-04 16:31
[ 0.071397] clocksource: Switched to clocksource arch_sys_counter
[ 0.150369] VFS: Disk quotas dquot_6.6.0
[ 0.150494] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.150704] FS-Cache: Loaded
[ 0.150933] CacheFiles: Loaded
[ 0.159853] NET: Registered protocol family 2
[ 0.160623] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.160754] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.160957] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.161114] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.161177] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.161483] NET: Registered protocol family 1
[ 0.162063] RPC: Registered named UNIX socket transport module.
[ 0.162088] RPC: Registered udp transport module.
[ 0.162108] RPC: Registered tcp transport module.
[ 0.162127] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.219682] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.223005] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.230577] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.230645] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.231284] NFS: Registering the id_resolver key type
[ 0.231333] Key type id_resolver registered
[ 0.231353] Key type id_legacy registered
[ 0.231430] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.232692] aufs 4.14.73±20190211
[ 0.233983] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.234134] io scheduler noop registered
[ 0.234156] io scheduler deadline registered
[ 0.234341] io scheduler cfq registered (default)
[ 0.234364] io scheduler mq-deadline registered
[ 0.234384] io scheduler kyber registered
[ 0.236825] BCM2708FB: allocated DMA memory f3900000
[ 0.236871] BCM2708FB: allocated DMA channel 0 @ b4813000
[ 0.268361] Console: switching to colour frame buffer device 228x61
[ 0.298929] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.300509] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.300799] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.301494] vc-sm: Videocore shared memory driver
[ 0.301917] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.311592] brd: module loaded
[ 0.320569] loop: module loaded
[ 0.320704] Loading iSCSI transport class v2.0-870.
[ 0.321631] libphy: Fixed MDIO Bus: probed
[ 0.321790] tun: Universal TUN/TAP device driver, 1.6
[ 0.322112] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.322545] dwc_otg 3f980000.usb: base=0xf0980000
[ 0.522860] Core Release: 2.80a
[ 0.522961] Setting default values for core params
[ 0.523116] Finished setting default values for core params
[ 0.723501] Using Buffer DMA mode
[ 0.723605] Periodic Transfer Interrupt Enhancement - disabled
[ 0.723767] Multiprocessor Interrupt Enhancement - disabled
[ 0.723925] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.724057] Dedicated Tx FIFOs mode
[ 0.724566] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xb3914000 dma = 0xf3914000 len=9024
[ 0.724853] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.725436] dwc_otg: Microframe scheduler enabled
[ 0.725492] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80638700
[ 0.725667] WARN::hcd_init_fiq:460: FIQ ASM at 0x80638a64 length 36
[ 0.725850] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 0.726065] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.726237] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.733704] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.741058] Init: Port Power? op_state=1
[ 0.748332] Init: Power Port (0)
[ 0.755717] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.763032] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.770309] usb usb1: Product: DWC OTG Controller
[ 0.777578] usb usb1: Manufacturer: Linux 4.14.98 dwc_otg_hcd
[ 0.784883] usb usb1: SerialNumber: 3f980000.usb
[ 0.792820] hub 1-0:1.0: USB hub found
[ 0.800170] hub 1-0:1.0: 1 port detected
[ 0.807931] dwc_otg: FIQ enabled
[ 0.807936] dwc_otg: NAK holdoff enabled
[ 0.807941] dwc_otg: FIQ split-transaction FSM enabled
[ 0.807950] Module dwc_common_port init
[ 0.808223] usbcore: registered new interface driver usb-storage
[ 0.815650] mousedev: PS/2 mouse device common for all mice
[ 0.822900] IR NEC protocol handler initialized
[ 0.830028] IR RC5(x/sz) protocol handler initialized
[ 0.837168] IR RC6 protocol handler initialized
[ 0.844276] IR JVC protocol handler initialized
[ 0.851300] IR Sony protocol handler initialized
[ 0.858397] IR SANYO protocol handler initialized
[ 0.865432] IR Sharp protocol handler initialized
[ 0.872358] IR MCE Keyboard/mouse protocol handler initialized
[ 0.879265] IR XMP protocol handler initialized
[ 0.886846] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.894080] bcm2835-cpufreq: min=600000 max=1400000
[ 0.901485] sdhci: Secure Digital Host Controller Interface driver
[ 0.908547] sdhci: Copyright© Pierre Ossman
[ 0.916230] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.920326] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.923590] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.927986] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.931338] hidraw: raw HID events driver © Jiri Kosina
[ 0.934696] usbcore: registered new interface driver usbhid
[ 0.937940] usbhid: USB HID core driver
[ 0.941535] vchiq: vchiq_init_state: slot_zero = b3980000, is_master = 0
[ 0.946034] [vc_sm_connected_init]: start
[ 0.955418] [vc_sm_connected_init]: end - returning 0
[ 0.958904] nf_conntrack version 0.5.0 (13312 buckets, 53248 max)
[ 0.962525] ip_tables: © 2000-2006 Netfilter Core Team
[ 0.966022] Initializing XFRM netlink socket
[ 0.969503] NET: Registered protocol family 10
[ 0.973204] Segment Routing with IPv6
[ 0.976383] NET: Registered protocol family 17
[ 0.979567] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 0.982983] Key type dns_resolver registered
[ 0.986478] Registering SWP/SWPB emulation handler
[ 0.990111] registered taskstats version 1
[ 0.996423] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.999857] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.004169] console [ttyS0] disabled
[ 1.007525] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 166, base_baud = 31250000) is a 16550
[ 2.083122] console [ttyS0] enabled
[ 2.090481] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.099790] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 2.108962] Indeed it is in host mode hprt0 = 00021501
[ 2.205476] random: fast init done
[ 2.232210] sdhost: log_buf @ b3913000 (f3913000)
[ 2.281785] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.292197] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.302634] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.314237] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.331395] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.331448] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.340726] of_cfs_init
[ 2.355906] of_cfs_init: OK
[ 2.370486] Indeed it is in host mode hprt0 = 00001101
[ 2.377804] Freeing unused kernel memory: 7168K
[ 2.489177] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.509751] mmc1: new high speed SDIO card at address 0001
[ 2.519387] mmc0: new high speed SDHC card at address 0007
[ 2.529580] mmcblk0: mmc0:0007 SD16G 14.4 GiB
[ 2.542983] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.611892] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 2.625589] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.637220] hub 1-1:1.0: USB hub found
[ 2.645090] hub 1-1:1.0: 4 ports detected
[ 2.981478] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.121813] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
[ 3.136646] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.153030] hub 1-1.1:1.0: USB hub found
[ 3.171916] hub 1-1.1:1.0: 3 ports detected
[ 3.253129] CP437: Invalid argument
[ 3.348994] fsck.fat 4.1 (2017-01-24)
/dev/disk/by-label/resin-boot: 156 files, 16694/80628 clusters
[ 3.401097] resin-rootA: clean, 5847/39936 files, 220650/319488 blocks
[ 3.538115] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 3.606800] resin-rootB: clean, 11/39936 files, 15349/319488 blocks
[ 3.692518] resin-state: clean, 64/5136 files, 1900/20480 blocks
[ 4.037301] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 4.071549] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
[ 4.151563] Under-voltage detected! (0x00050005)
[ 4.211716] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
[ 4.222398] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.181730] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.249213] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 5.728147] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.758632] aufs au_opts_verify:1609:init[1]: dirperm1 breaks the protection by the permission bits on the lower branch
[ 7.561739] systemd[1]: System time before build time, advancing clock.
[ 7.585792] systemd[1]: systemd 239 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 7.615392] systemd[1]: Detected architecture arm.
[ 7.661764] systemd[1]: No hostname configured.
[ 7.674708] systemd[1]: Set hostname to .
[ 7.696177] systemd[1]: Hardware watchdog ‘Broadcom BCM2835 Watchdog timer’, version 0
[ 7.712759] systemd[1]: Set hardware watchdog to 10s.
[ 7.842618] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.869292] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.437243] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.457144] systemd[1]: Created slice system-getty.slice.
[ 8.501946] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.518198] systemd[1]: Listening on udev Control Socket.
[ 8.561577] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.066572] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 13.856498] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.885939] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 14.069419] libphy: lan78xx-mdiobus: probed
[ 14.111193] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 14.163845] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 14.171108] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
[ 14.197109] usbcore: registered new interface driver brcmfmac
[ 14.299165] usbcore: registered new interface driver lan78xx
[ 14.475762] random: crng init done
[ 14.489266] random: 7 urandom warning(s) missed due to ratelimiting
[ 14.667863] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 14.691021] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
[ 16.547679] uart-pl011 3f201000.serial: no DMA platform data
[ 18.935834] i2c /dev entries driver
[ 20.183861] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.201555] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.281575] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.325468] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.342171] brcmfmac: power management disabled
[ 20.887121] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.903377] brcmfmac: power management disabled
[ 21.283757] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 22.230511] Bridge firewalling registered
[ 22.699770] Netfilter messages via NETLINK v0.30.
[ 22.710812] ctnetlink v0.93: registering with nfnetlink.
[ 23.370456] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
[ 23.530630] Bluetooth: Core ver 2.22
[ 23.534826] NET: Registered protocol family 31
[ 23.539563] Bluetooth: HCI device and connection manager initialized
[ 23.546437] Bluetooth: HCI socket layer initialized
[ 23.551640] Bluetooth: L2CAP socket layer initialized
[ 23.557001] Bluetooth: SCO socket layer initialized
[ 23.583680] Bluetooth: HCI UART driver ver 2.3
[ 23.588444] Bluetooth: HCI UART protocol H4 registered
[ 23.594024] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 23.601213] Bluetooth: HCI UART protocol Broadcom registered
[ 23.778555] IPv6: ADDRCONF(NETDEV_UP): br-2ca4fb48f74d: link is not ready
[ 24.120556] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 24.126458] Bluetooth: BNEP filters: protocol multicast
[ 24.133710] Bluetooth: BNEP socket layer initialized
[ 24.146182] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[ 24.964003] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.970331] brcmfmac: power management disabled
[ 28.232334] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 36.790592] ip6_tables: © 2000-2006 Netfilter Core Team
[ 83.192104] Voltage normalised (0x00000000)
[ 89.432637] Under-voltage detected! (0x00050005)
[ 93.592102] Voltage normalised (0x00000000)
[ 95.672126] Under-voltage detected! (0x00050005)
[ 131.032365] Voltage normalised (0x00000000)
[ 391.030822] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 391.030829] Under-voltage detected! (0x00050005)
[ 418.070748] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 418.070754] Voltage normalised (0x00000000)
[ 426.390745] Under-voltage detected! (0x00050005)
[ 432.630718] Voltage normalised (0x00000000)
[ 445.110744] Under-voltage detected! (0x00050005)
[ 644.791646] Voltage normalised (0x00000000)
[ 692.632080] rpi_firmware_get_throttled: 1 callbacks suppressed
[ 692.632086] Under-voltage detected! (0x00050005)
[ 698.872250] Under-voltage detected! (0x00050005)
[ 725.912503] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 725.912510] Voltage normalised (0x00000000)
[ 732.152585] Under-voltage detected! (0x00050005)
[ 736.312640] Voltage normalised (0x00000000)
[ 763.352664] Voltage normalised (0x00000000)
[ 1031.672157] rpi_firmware_get_throttled: 6 callbacks suppressed
[ 1031.672163] Voltage normalised (0x00000000)
[ 1042.072177] rpi_firmware_get_throttled: 8 callbacks suppressed
[ 1042.072186] Under-voltage detected! (0x00050005)
[ 1046.232156] Voltage normalised (0x00000000)
[ 1048.312165] Under-voltage detected! (0x00050005)
[ 1073.272163] Voltage normalised (0x00000000)
[ 1081.592194] Under-voltage detected! (0x00050005)
[ 1343.671911] rpi_firmware_get_throttled: 9 callbacks suppressed
[ 1343.671920] Voltage normalised (0x00000000)
[ 1349.912004] rpi_firmware_get_throttled: 9 callbacks suppressed
[ 1349.912012] Under-voltage detected! (0x00050005)
[ 1368.631951] Voltage normalised (0x00000000)
[ 1379.031896] Under-voltage detected! (0x00050005)
[ 1385.271886] Voltage normalised (0x00000000)
[ 1387.351972] Under-voltage detected! (0x00050005)
